Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Pool Construction Nightmare
    Aug 2015
    Katy/Texas
    6
    I have spent a lot of time searching for information concerning pool construction problems. Our construction began in June. I should have known we were in trouble when they cut the power line we paid $1900 to move. Nearly yanked the meter of the wall.
    It seems like every Phase of construction has had problems. We were on vacation when they did the gunite. I came home to find that the top edge of the back wall was 8" thinner on one side. Although the inside of the pool was a straight line the back side tapered from one end to the other. I was told that the tile guy would fix it with mud so that both sides of the wall would be the same width when completed. But he did nothing. Consequently, the concrete guy improperly lined up his form on that side. The taper continued all the way to the fence where it was measured to be off by a foot. This would have caused the loss of several square feet of deck space.
    The biggest issue, however, has been the flagstone coping and stacked rock walls. Strikingly similar to a post I read on this forum dated 2011. The golden buckskin color we chose was not what was put on the pool. It was reddish pink or rosa. Did not even come close to matching the tile we picked. My wife was in tears so I confronted the PB. It was a battle to say the least. I won't bore you anymore than I already have, but I am a lawyer. Ultimately, they agreed to demo the pink stone and install the correct color. To make sure it was right this time, my wife and I went to the stoneyard and picked 3 pallets of flagstone. The difference was night and day. Amazingly, it matched our tile too. Go figure.
    Here is the current issue. The "tile guy" and his crew were less than thrilled to demo the pink disaster and start over. I actually stayed home the day they installed the new stone. I have 2 stacked stone walls 25' long each and approx 2.5-3' high. The pink job had 2 guys working meticulously with a level and mortar while a third guy cut stone and they finished about 1/3 of the wall in a day. This time, only one guy stacking stone and he did twice as much in the same amount of time. It seemed like He was throwing mud and stone in the wall, never used a level, and really did not care how it looked. Now, there are places in the wall where there is more mortar than stone, cracked mortar, holes in mortar, etc. I noticed the same problem on the fire pit that they did the following day.
    This work was done this week. Is this normal? Am I stressing over nothing. I will send pics as soon as I figure out how to attach. I appreciate input.
    LongDuck's Avatar
    Aug 2015
    Phoenix, AZ
    39
    Re: Pool Construction Nightmare
    Just wanted to mention up front that what you're going through is NOT normal. Our new construction in-ground went exactly to schedule and we were home for every action done throughout construction due to having a dog and secure access. The PB stated a run time of 6-8 weeks from excavation to swimming, and they did it in 7 weeks total. I was able to have a hand in every step, including grill island, firepit, and pool excavation, rebar, shotcrete, and pebble. The crew was on site daily like clockwork, and early morning, and used levels, guide strings, and other specific method and tools throughout. The same guys showed up each time for consistency and I handed out cold Gatorade and water, which they appreciated.
    Choosing a PB can be a shot in the dark, but referrals and online reviews go a long way to ensuring best quality and satisfaction. At this dire point in your construction, it might make sense to end the current contract for non performance and start with contractor estimates to repair what's there or demo to your satisfaction and go from there.
    Recently in Phoenix, a longtime PB (Paddock Pools) was sold to new owners who started projects, took deposits and then performed minimal shoddy work until bankrupt. It happens sometimes, and so sorry to hear your story. In the end, the final product needs to meet your standards of quality and beauty, and if things aren't going well now, I can only hope they'd get better.
    Edited to add, check with your ROC, as there is a fund for work to repair problems with a ROC contractor who doesn't keep to their standards.
    July2015 New - 12,900gal IG Clorine Pool: Free Form Shot/PebbleSheen, Ceramic Waterline/Travertine Coping/Deck, Paramount PV3 In-Floor, Pentair 3050VS Intelliflo Variable (3000rpm High/1000rpm Low), Pentair Clean & Clear 420 Cartridge, Venturi Skimmer, MDX/SDX Drain, Paralevel, Rock Waterfall +3/4" Aireator, Intellibrite 5G LED, EasyTouch4, and Tab Floater.
    Aug 2015
    Katy/Texas
    6
    Here are a few photos. I can only upload 3-4 at a time.
    Jun 2015
    Raleigh
    357
    That's not acceptable stone work under anyone's definition. I wouldn't accept that.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Aug 2013
    Arab, Alabama
    422
    Looks to me like the stone mason had one drink too many!
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Aug 2015
    Katy/Texas
    6
    Those are just a few of over 50 photos I have of holes in the mortar, cracks, crooked stones, v-shaped mortar lines in the coping, and large areas where there should be stone but they decided to simply fill in with mortar. I would upload them all if I could, but either I don't know what I'm doing or the site is limiting me to 250KB of upload files on the thread.
    Bottom line it sounds like I'm not crazy and that this is substandard stone work. The pool company has been around a long time. However, the customer service and quality control has sucked to say the least. No one from the company even came by during the demo or re-installation to see if sub was doing a good job.
    Jun 2015
    Raleigh
    357
    For photos easiest to get a free photo bucket account. Then you can upload them there and link the entire album or individual pictures...as many as you want.
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    JoyfulNoise's Avatar
    May 2015
    13,225
    Wow, that just looks shoddy, to say the least. You are well within your rights to tell them to rip it out.
    You said the PB has never been on site?!?! You need to go directly to the PB and not deal with any of the subs. That work is ridiculous and amateurish. The PB should be ashamed that his masonry subs did that.
    Matt
    Shekkie's Avatar
    Jul 2015
    Grafton, Ohio
    68
    That is terrible work and the mess left behind looks completely unacceptable as well.
    Aug 2015
    Katy/Texas
    6
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Wow. I would NOT accept that. I am freaking out over here on your behalf!! A new pool is a huge investment, and you are right. This PB is not holding up his end of the contract. At this point, I would tell them to demo as much as possible and start again. What about the plumbing, etc.? Any issues there? I'd also get the BBB involved if the company isn't responsive to you.
    Sorry you and your wife have to go through this!
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Jun 2015
    New Orleans, LA
    20
    I have no experience what so ever doing masonry, but if I was DIY'ing it and it looked like that I'd tear it down and start over. I definitely wouldn't accept that level of work from a "professional". Wow, really sorry to hear you're having so many difficulties.
    Jul 2015
    Kentucky
    1,126
    Wow that's sad. I'd be royally ticked too. You are Not being unreasonable at all that is really shotty work. I agree with jduck that it looks like someone stayed too long at Charlie's Bar again. I would definitely contact the PB, and make them fix all that mess before going any further because that is totally uncalled for. You can tell they didn't use a level, or spacers, or anything to keep them in line. They just stuck the stones up there, slapped some mortar on them, and hoped they stayed.
    On a more positive note though, I love the colors you, and your wife picked. IF they ever get it fixed correctly it's going to be very pretty. It's probably good you are a lawyer because you may very well be needing one soon. Just smh, you're spending all that money to have something nice for you and your family, and the work they're doing looks like that. I am truly sorry that you and your wife are being put through all that. Anyway, try your best to have a good night, and PS-Don't look out the window.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    O. M. G. !!! That is absolutely horrible! My kids could do at least that good of a job, and my oldest is only 8. Can't wait to see how this one goes. Good luck.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2014
    St. Louis, Mo
    26
    Sorry you are having problems with your pool build. It seems like the tile company is upset with the pb and they screwed up the redo on purpose to make a point. If your pool builder is reputable, he will take responsibility and have another tile company redo the stone work. Good luck.
    domct203's Avatar
    Jun 2015
    CT
    3,591
    Wow, I'm so sorry to see this. That is some of the worst stone work I have ever seen.
    If that was my pool I wouldn't let another one of those amateurs near it again.
    Tell the PB you want another contractor IMMEDIATELY!
    Best of luck,
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2015
    Houston, Texas
    3
    Don't mean to beat a dead horse but that's bad... really, really bad.
    14,000 gallon in ground, gunite. Hayward TriStar SP3200VSP, Hayward 6060 Booster, Hayward SwimClear
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    How is your payment schedule set up?
    Aug 2015
    Katy/Texas
    6
    I really appreciate everyone's input. I am putting hold on project until I can have another stone/and tile guy take a look and tell me what needs to be done. Then I will sit down with PB. At this point I simply can't trust PB or its sub. I want it done right, whatever it takes.
  20. Back To Top    #20
    May 2015
    13,225
    Good luck. Keep posting updates if you can, these threads are very important to people looking for pool build info. It teaches a lot about what can happen and how to fix it.
    Matt
