Results 1 to 19 of 19
Thread: Slow?
    38,237
    Slow?
    Is the forum slow today?
    Or is it my ridiculously over-priced and way under performing "high speed" Comcast gestapo internet service?
    Jun 2014
    14,970
    Re: Slow?
    Three cheers for over-priced, slow internet service. Hip-hip, hooooooooooory.
    I'm zipping along okay ... so far.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Slow?
    Seems to be working well up here in the NE via Cablevision
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    38,237
    Re: Slow?
    Every so often it just freezes up.
    I got sick of Comcast autocalling me multiple times a day saying my old modem was not good enough to make use of the speed of my internet (50MB on promotion as the cheapest option) ... I was consistently getting 30MB which is more than enough for our needs.
    So I upgraded to a new docsis3 cable modem .... and now I swear my internet is slower and more flaky
    30,402
    Re: Slow?
    After a nightmare with Comcast here in Florida, I googled somewhat interested in suing them. The hits are amazing. Comcast is one bad company.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Slow?
    Exactly what happened to me. AT&T pestered me for months to "upgrade" from 6mb Uverse to 18mb Uverse. Finally I said yes and it freezes more often and seems slower. But the speed test says it is faster so there is no problem. Hooray!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Slow?
    Its probably COmcast. Im not having any problems at all.
    Last edited by Divin Dave; 08-15-2015 at 03:14 PM. Reason: edited to remove something I shouldnt have said!
    Divin Dave,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Slow?
    When I was having issues with uverse a couple of years back and got no where doing their home diagnostics they finally sent a tech guy out. He examined everything and told me uverse had upgraded their service and the my older equipment was not very compatible and would continue to cause problems until it was changed out. He ran new wires to each room and switched out the modem and it has worked fine ever since. I was irked it took so many calls to get someone to come fix something I had no control over, especially when they already knew what the problem was.
    Love TFP? Become a
    TFP Supporter!
    38,237
    Re: Slow?
    Luckily we do not get rain often. Because when we do, the internet stops working. Their lines must be in bad shape. Of course they can still claim 99+% up time
    I so wish there was another option.
    Jun 2011
    Long Beach, CA
    2,778
    Re: Slow?
    Jason,
    Have you tried using DSLReports to find info on your issues with comcast? I find this is a nice place,Comcast HSI forum | DSLReports, ISP Information, to find a lot about all the issues these types of providers are having.
    30,402
    Re: Slow?
    I am convinced that the phone company is gonna get this all figured out. We get quite a bit of programming over our Centurylink DSL but no live TV yet. So far it is completely free but that will cahnge as more things become available.
    Meanwhile, Comcast can kiss my cheek(s).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Slow?
    Seems fine to me. http://www.speedtest.net/ shows me at 25.54 Mbps download, 23.97 Mbps upload.
    Jun 2011
    Long Beach, CA
    2,778
    Re: Slow?
    I'm waiting for the big change for all of us in California, Texas, and Florida that have Verizon as we just got our notice that Verizon is selling all land line business to Frontier early next year. TV, internet, and land line phones are all going to be Frontier. I have to say my internet has been flawless for the last 8 years or so and I get 75 Mbps download and upload.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Slow?
    ...So I upgraded to a new docsis3 cable modem .... and now I swear my internet is slower and more flaky
    Cox kept telling me to upgrade to a docsis3 cable modem. Since I needed better range in the house, I upgraded w/ a new Motorola Surfboard. Fixed my range problem, but I can't tell that it made any difference in my internet speed. Can't see what benefits docsis3 provides.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    38,237
    Re: Slow?
    Docsis3 is required for anything over about 30MB ... although rarely does anyone actually need such high speeds. Maybe when things start streaming 4k TV these higher speeds will be required.
    Docsis3 has nothing to do with range in the house ... sounds like you just needed to upgrade your wireless router, not the cable modem. Of course now they sell them combined. I did not want to go that route. After all the older surfboarded I just stopped using was working fine after I have had it over 10 gears. But in that 10 years wireless has greatly improved. I know the modem should be good for a LONG time, but may want to upgrade the wireless or even the router itself again before a new cable modem will be needed.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Slow?
    While I'm not 100% sure what was going on there appears to be something that was slowing down TFP yesterday at about 7:30pm EST. For those whom reported this, it wasn't just you.
    I'm keeping an eye on it for now and hope to pinpoint the cause.
    Lee
    Jul 2009
    Houston, Texas
    9,376
    Re: Slow?
    Maybe it was something on the served end?
    Love TFP? Become a
    TFP Supporter!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Slow?
    Quote Originally Posted by ping View Post
    Frontier bought all of Verizon's rural holding a couple of years ago. Up until that point Verizon refused to do any upgrades near out mountain property to,provide DSL so all the neighbors were using Hughes Net satellite internet. When Frontier came in they upgraded the facilities and now DSL for everyone! I would say look to the Verizong to Frontier switch as a positive one.
    Support the site
    May 2014
    Franklin, NC
    9,179
    Re: Slow?
    My range in the house has been slowing going down for a while, so,it,was time for an upgrade. As I didn't want to deal with Time Warner for an equipment swap I decided to go with an access point. I purchased a UniFi access point and set it up. I disabled the wifi in my combo router/wifi and use the UniFi. It doubled the range and if I want I can add additional UniFi access points to,extend the network. With multiple units they see each other and hand off the access as you move through the house. They even have a weatherproof unit for out by the pool.
    Support the site
