Thread: Sand filter pressure high after backwash
    Aug 2015
    oklahoma city, ok
    1
    I've been caring for this pool for 2 years. I know when its time to back wash by the spa over flow (and of course I monitor my pressure) I have been back washing and the sand filter pressure is not going down!! I used your method to clean my sand (no change). I do use my chlorinator and I took out all of the tablets and cleaned the grill. there were some small broken pieces down in the bottom. What should I be looking for?
    45,000 gal in ground pool with spa, 2 waterfalls, and slide, heater, sand filter, ozone with chlorinator, use the SLAM method and bleach method for shocking
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Sand filter pressure high after backwash
    Is the visual check of the spa overflow showing a problem, or does it look normal? It could just be a bad gauge.
