Thread: Removing booster pump - no longer needed
    Jun 2012
    Woolwich Twp, NJ
    7
    My pressure cleaner, Pentair Legend Platinum (driven by 3/4 HP booster pump), has been replaced by my newly purchased Dolphin Nautilus. I am going to remove the booster pump and plug the inlet and outlet plumbing the pump used to connect to. Is that all I need to do?
    The inlet for the booster was running off a T after the pool filter.
    The outlet for the booster was running off a dedicated PVC pipe that was connected to a Y running to the dedicated return for the cleaner. Though I cannot see the Y, it must be a Y since the return still has water coming out if I turn the booster pump off and the main pump is still running.
    Thanks for the best pool forum on the Net.
    30K gallon free form vinyl IG pool with waterfall
    Hayward DE3620, Pentair Superflo 1.5 HP
    Dolphin Nautilus
    4 returns, 2 skimmers, 1 bottom drain
    1.5 inch plumbing
    38,526
    Re: Removing booster pump - no longer needed
    There may not be a Y. The main pump could still move water through the booster pump even when it is off.
    Jun 2012
    Woolwich Twp, NJ
    7
    Ah, didn't think about that. Thanks!
    When I disconnect the booster from the plumbing, plug the T where the inlet connected, I'll check the return for any flow.
    Dolphin Nautilus
    1.5 inch plumbing
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    Sounds like you have it figured out.
    Enjoy the Nautilus. I have one and it does a really good job for a moderate price. 2 years now with 0 problems.
    Divin Dave,
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    That pipe for the cleaner is really just another return to your pool so you could hook from the Tee to the pipe and add another return to your pool if you wish. Likely, it will be a smaller pipe that your 'official' return pipes. All my returns are 1.5" but the tee is 3/4" and the actual pipe is 1". Just a thought....
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
