Thread: VS Pump Suction, Discharge, and Air Bubblest
    Jul 2015
    Parsippany, NJ
    2
    Hello TroubleFree,
    looking for some help in diagnosing air bubbles in my VS Pentair Intelliflo 3HP pump strainer basket. There is a pretty steady air bubble that is present under normal operation regardless of speed that has been present since installation. I attempted to check the new plumbing by pouring water over all joints to see if air disappeared but was unsuccessful. The interesting thing is thing is that I recently went to discharge water from pool via waste outlet on multi port and during this operation no air bubble.
    normal filter operation... Suction 5 psi. Discharge 15 psi... Filter 15 psi
    waste operation... Suction 10 psi... Discharge 10 psi
    all lines in pool are 1.5" but I upgraded to 2" on the equipment pad. Running pump at 2350 rpm
    Do do I actually have a leak on suction?
    16'x32' vinyl inground ~21,000 gal
    1.5" piping supply and return
    2" piping on equipment pad
    Pentair intelliflo 011018 3HP
    Hayward DE 48sf? filter
    38,262
    Re: VS Pump Suction, Discharge, and Air Bubblest
    Welcome to TFP!
    Is air filling the filter?
    Is air entering the pool?
    Or do you just see a bubble sitting at the top off the pump lid? This is not uncommon, especially when running at lower speeds.
    Jul 2015
    Parsippany, NJ
    2
    Hey thanks for the quick reply!
    very little to no air in filter when bleeding
    no air bubbles in return jets
    just see a bubble in filter basket, but was unsure why i get a higher suction and no air bubble when put in waste. I did the plumbing myself so wanted to make sure there were no leaks that I need to address.
    so you think it's fine?
    38,262
    On waste, you are just able to achieve a higher flow rate which clears the bubble out of the pump.
    If you are not getting a build-up in the filter or seeing a lot of small bubbles spinning around the pump, you are likely fine.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    My IntelliFlo usually has a few bubbles sitting on top of the strainer basket caught in the "spider-web" of the lid and everything appears to be working well. My pump primes in under 10 seconds regardless.
    I'm sleeping fine at night with it.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    That is normal, especially at lower speeds.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
