Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Newbie here. Just fill up my 22,000gal agp. Here are my test results with two chlorin
    Mar 2015
    Liberty/Tx
    48
    CYA-0
    Chlorine-0
    PH-8
    Hardness-125
    TA-140
    I have no clue what I'm doing
    Saltwater 8000 30ft round AGP / 22,000 gal / 1Hp Hayward variable speed super pump / Hayward 150sqft cartridge filter / Hayward Aquarite 25k gal salt system / katchakid
    Mar 2015
    Liberty/Tx
    48
    Re: Newbie here. Just fill up my 22,000gal agp. Here are my test results with two chl
    Using 2- HTH Ultra 3" chlorine tablets in two floaters
    Mar 2015
    Liberty/Tx
    48
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    1) Get the pump and filter going.
    2) Add 2 ppm FC using bleach. Poolmath can crunch the numbers for you. Expect it all to disappear within hours.
    3) Add 40 CYA using the sock method
    4) By the time you're done messing with the sock, the chlorine will have mixed and you add some acid to get pH to 7.4. 7.2 will work better to lower the TA, but the pool volume isn't always what you calculate. Better to underdose than overdose.
    5) Grit your teeth against the chilly water and
    6) Day two: add 3 FC. Recheck pH and TA and adjust if pH is above 7.8.
    7) Day 3: The CYA should all be dissolved, so target 6 FC. Target, don't add. You might have some residual, so test first and let poolmath tell you how much
    8) Days 4-6, Target 6 FC and keep pH between 7.2 and 7.8. Probably need to brush and vacuum somewhere in there.
    9) Day 7, measure CYA. Run all the tests in fact. Post results.
    It's really just that simple. You're starting fresh, so you can be in complete control from day one.
    Oops. I see you have updated and posted again. You shouldn't be adding metals to the water. Those pucks add zinc. Also CYA. A steady diet of those pucks will drive CYA too high, cause pH to crash, and ultimately stain the liner. It's sad to see you give up on our methods before you even gave them a chance.
    Mar 2015
    Liberty/Tx
    48
    Sorry, I really didn't know the methods. I printed out pool school but it was a little confusing where to start with a fresh new pool
    Mar 2015
    Liberty/Tx
    48
    Pump and filter have been running for about 3 days and the pucks have been in there for three days
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hi Ranchdip, I gotta ask, what are you testing with. a good test kit, I hope. I would remove the pucks and follow Richard directions. don't know how much CYA is in your pool from pucks, But I bet Richard will know. (he's very knowledgable )
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Mar 2015
    Liberty/Tx
    48
    Ok will do
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Here are some useful references links.
    Please ask if there is something you dont understand. We'll be glad to help you.
    Pool School - Chlorine / CYA Chart
    And Pool Math along with your test kit are your best friends
    http://www.troublefreepool.com/calc.html
    Divin Dave,
    lefty51's Avatar
    May 2015
    451
    Divin Dave always has the right links for the job,
    Mar 2015
    Liberty/Tx
    48
    Thanks so much guys. Y'all have been a huge help!
    Mar 2015
    Liberty/Tx
    48
    Using the TF-100 test kit. However, it's been sitting in my garage for a year
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Inside in the air conditioning would have been better.
    Please add your pool info to your signature as shown here, Pool School - Read This BEFORE You Post
    Mar 2015
    Liberty/Tx
    48
    Will do
    Mar 2015
    Liberty/Tx
    48
    Newbie here. Just fill up my 22,000gal agp. Here are my test results with two...
    Today's results. Hopefully my kit hasn't been compromised since it wasn't air conditioned.
    FC= 1.5ppm
    TA=170
    CH=150
    Ph= 7.5
    Mar 2015
    Liberty/Tx
    48
    Quick question: I have the stabilizer going in the sock. Considering my current numbers. Can I let my boys swim?
    DFW, TX
    24,502
    It is safe to swim when
    PH is 7.2 to 7.8
    Chlorine is above minimum and below shock level
    for your CYA, Chlorine CYA Chart
    Water is clear
    Mar 2015
    Liberty/Tx
    48
    Thanks! So, even though I have stabilizer leaching through the sock at this time it's ok to swim in? Thanks so much guys! I really feel I'm getting a grip on this.
    Mar 2015
    Liberty/Tx
    48
    By the way, the water looks great
  20. Back To Top    #20
    DFW, TX
    24,502
    Yes, the stabilizer is fine. Good news!
