Thread: Sta-rite Max-e-therm manifold removal/replacement question
    Nov 2014
    Seffner, FL
    15
    HI all, I have a Sta-rite 200 and need to replace the manifold bypass valve which requires removing the manifold and reinstalling. My question is will I need to replace the coil/tube sheet o-rings and manifold o-ring as well? Thanks so much in advance!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Sta-rite Max-e-therm manifold removal/replacement question
    Never done the job personally, but my vote is yes. Replace any O-rings you disturb.
    From my experience working on cars, I can say that O-rings will get stiff and take a set and won't reseal well when reused.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    +1 to what Richard said. It's best to always replace O-rings. If it's good for fuel or A/C applications, I think it applies to everything
    But then again... I always like putting new stuff in
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    I always replace the o-rings and the thermo regulator as part of this type of job.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Nov 2014
    Seffner, FL
    15
    Thanks everyone for the replies!
