Results 1 to 7 of 7
Thread: CoverFree?
    Jul 2015
    Riverview, mi
    24
    CoverFree?
    Has anyone used CoverFree? I'm looking for a way to keep my above ground pool warmer without using a solar cover.
    21' Round. Above Ground. Doughboy. Sand Filter. TF-100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: CoverFree?
    it looks to be generally safe, a rating of 1 for health.. you should take a shower after using the pool and it says not to discharge water into drains?? do they know its going in a pool??
    https://media.nat.cm/filer_public/ed...ds_-_aug14.pdf
    Donldson's Avatar
    NW Ohio
    2,906
    Re: CoverFree?
    Do a search on the forum for liquid solar covers. At best they do almost nothing to improve heat retention, which makes sense when you really consider it. How well can a thin layer of oil really prevent heat from escaping your pool at night?
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2015
    Riverview, mi
    24
    Re: CoverFree?
    I didn't know it was rated 1 for health! My dogs often float with me and sometimes take a drink of water (even though I tell them no!). Maybe it wouldn't be a good idea then. ?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CoverFree?
    Quote Originally Posted by Donldson View Post
    When there is no wind then they DO retain heat indirectly by significantly lowering the amount of evaporation (see this post that shows that 1/4" of evaporation will lower a 4.5 foot average pool depth temp by 4.9F). About half a pool's heat loss comes from evaporation of the water, NOT from conduction or radiation. So these liquid pool covers DO work IF there is no wind. However, that's a big "if". With wind, the single molecule layer tends to get pushed to the side exposing water to be evaporated.
    A bubble-type cover is obviously a lot better, not just because it is not affected by wind, but also that it not only prevents evaporation, but has air bubble insulation that significantly reduces conduction. Whereas a thin non-insulating cover and perhaps these liquid solar covers with no wind may cut down heat loss in half, the bubble-type cover cuts down that remaining loss in half again. So if one were to lose 6F overnight with no cover, a thin or liquid cover may cut the loss down to 3F while a bubble-type cover would cut it down to only 1.5F. These covers also work during the day, but then in addition to heat losses there is heat gain from the sun heating the water in the pool. Very roughly speaking, you can expect a bubble-type cover to raise pool temperature above the average day/night about twice as much as a thin or liquid cover. So instead of a 10-15F increase, you may only get a 5-7F increase.
    I have an automatic electric safety cover and it is relatively thin and not very insulating so in my pool I only get a roughly 50% reduction in heat loss due to preventing evaporation. If I were to use a bubble-type cover, I'd retain more heat, but it wouldn't be automatic. Since I have a solar system to heat the pool, it nets out OK for the convenience of an automatic cover.
    Quote Originally Posted by Tvaughn6 View Post
    As for the "1" for health which means a SLIGHT health risk, that is referring to the CONCENTRATED chemical. The 1,2-Propanediol will evaporate (it's just used as a carrier for dispersion), but the 1-Octadeconal (aka Stearyl alcohol) that remains has an LD50 better than table salt. Most certainly when diluted as a thin one molecule layer on the water, it will not be hazardous even if your dog drinks from the water.
    Jul 2013
    Fletcher, OK
    3,353
    Re: CoverFree?
    Quote Originally Posted by chem geek View Post
    thanks Richard, I saw the "1" and was not sure if it was from the bottle "concentrated" or when deployed in the pool..
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: CoverFree?
    I use cover free and it does in fact do something, though I'm sure not as much as a real cover. On cold, Mchigan mornings, the difference between having topped up the cover free and not is truly visible in the volume of fog coming off the pool! In wind, however all bets are off
    I haven't been expspecially scientific about it, but I know my gas bills were higher before I started using it.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
