Thread: 3/8" pitch on equipment pad?
    Jun 2015
    Hooksett, NH
    4
    Hi All,
    I have been installing my inground fiberglass pool this summer, a Trilogy Genesis, and the 4x8 pad I poured was set with a pitch for drainage. It is set into a hillside and I wanted good drainage. I can reduce the pitch to level but think this will work well for its location.. Can anyone advise as to whether a pool pad "must" be level or a pitch is perfectly acceptable for drainage?
    Best to all
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: 3/8" pitch on equipment pad?
    I can't say if it needs to be completely level, I was in the same boat... (just reread your post, did you already pour the slab? if so ignore the pictures )
    I went with 1 inch gravel 4 inches thick and used 1 inch 24x24 cinder block to put my equipment on.. I can say it drains great and no issues with being level, I leveled each block and also level between both blocks.. It does not look as "professional" as a cement pad but I can do anything to it later if I need to add to my equipment.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    It doesn't matter...I'd just make it level. All your equipment is raised a bit above the pad anyway.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    With that sort of set up, I dont think it really matters. Your equipment is above grade - being the gravel - and its nowhere near your homes foundation, so your good.
    BTW, nice setup you have there. I like it.
    Divin Dave,
    Jun 2015
    Hooksett, NH
    4
    Thank you for the advice.
