Results 1 to 7 of 7
Thread: Replaced timer and is not working properly
    Aug 2015
    Andrews/texas
    4
    I have a speck pump and recently had to replace the timer. The timer was sent from speck itself. I had my electrician put it in. First my last timer had three settings - auto off on. This timer has only auto and on. The on position does not work. The auto works and I am able to adjust with the pins but nothing happens when I switch it to on. I called speck they sent another timer which I again put in and it's still doing the same thing.
    6000 gallon in ground swim spa with sand filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Replaced timer and is not working properly
    Got any pictures?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2015
    Norfolk, VA
    9
    Disregard missing the off setting, that just puts the system into service mode, not important and shouldn't change the wiring. Does the timer keep time? What is the voltage of the pump and the timer they supplied?
    Service Manager for Gracia & Vigil. Specialize in concrete pools, commercial and residential, but if the pool is in the ground I can fix it!
    Aug 2015
    Andrews/texas
    4
    I will have to get back with the voltage of the pump. I just replaced the timer with a second new one and it's doing the same thing. It appears to be lagging time, like an hour a day. The timer would not shut the system off yesterday. As it turns its pulling the pegs in keeping the system on. The on position still is not working. Speck people are stumped?
    Aug 2015
    Andrews/texas
    4
    The voltage is 230/115
    Jun 2012
    western NY
    1,562
    Quote Originally Posted by Dmuennink View Post
    It will be either/or. What power are you using? The 120 or the 240 and is the timer compatible with that voltage?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Aug 2015
    Andrews/texas
    4
    230. Sorry I'm not save on electrician issues
