Thread: Lowering TA
    Jun 2015
    Wamego/KS
    120
    Lowering TA
    FC 5
    CC .5
    Ph 7.2-7.4
    TA 175
    How do I get my TA down to the normal range??
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Aug 2014
    Northern IL
    4,615
    Re: Lowering TA
    Here you go: Pool School - Lower Total Alkalinity
    Let us know if you need help figuring it out!
    How are your wrinkles, btw?
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Lowering TA
    Acid is needed to lower your TA. However, it'll also effect your pH.
    This will take some time and patience due to the double-effect Muriatic Acid has on both your pH AND TA.
    Lower your TA with acid and then aerate your pool to help raise the pH back up. In fact, I'd aerate NOW or set up to aerate somehow and work on raising your pH.
    When the pH is nice and high (7.8 - 8.0 ish), you can hit it with acid.
    Well, I guess the link is echoing what I'm telling you. LOL!
    You may wish to 'work on' figuring out a good way to aerate your pool. I made myself a PVC 'rack' (2" PVC filled with sand) in which I wrapped a soaker hose around and then hooked my air compressor to the soaker hose to create some serious bubble action. If you can get a good aeration program down, you can make this go a bit faster but it will take a couple weeks.
    What is the TA of your fill water? A water change could possibly help.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Lowering TA
    If your pH isn't rising and your CH isn't high, you could just leave the TA where it is. It's not required to lower the TA to the Recommended Levels range unless you have a potential scaling problem (i.e. pH and/or CH also run high) or your pH tends to rise and you have to add acid regularly to keep it down.
    Re: Lowering TA
    What are your calcium and cyanuric acid levels?
    What do you use for chlorine?
    Support the site
    Jun 2015
    Wamego/KS
    120
    Re: Lowering TA
    My ph does rise every couple weeks and I lower with acid. CH is within normal range. CYA is high...90. Are there potential issues that can arise due to high TA? Wrinkles are still there.
