Thread: How can check to make sure main drain is working?
    bsweat1981's Avatar
    Aug 2015
    Trinity,NC
    4
    I paid extra for a main drain on my above ground pool supposedly do reduce vacuuming but it doesn't appear to have any suction when I touch it. Wouldn't you be able to feel it sucking even if just a bit. I kind of feel like it's not even working. Maybe its just there but not really hooked up. I just had pool installed a few months ago.
    18x30 52" Swim and Play above ground
    Pentair Dynamo Pump w/sand filter
    My pool is my happy place.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: How can check to make sure main drain is working?
    I can't feel any suction on my main drain normally. Do you have a valve to switch between skimmer and drain? I move the valve to all drain when I brush the pool and the dust disappears down the drain.
    38,359
    If you can turn off the skimmer and water keeps moving ... then it has to be coming from somewhere
