Results 1 to 17 of 17
Thread: Chlorine Odor Question
    Jun 2015
    Saunderstown RI
    7
    My pool is running fantastically, no odors at all. However, I have a curiosity question. To make a bad pun, something I continue to read here just doesn't pass the sniff test. What's at issue is the assertion that the chlorine smell is caused by chloramines, not chlorine. If that's true, why does bleach have the same, though much more concentrated smell? Surely, there are no chloramines in bleach?
    Not looking to cause trouble, but this doesn't make any sense to me.
    32,500 Gal. IG Vinyl Pool, DE Filter, 2 Hp Haywood Pump, Booster Pump for Polaris, Biogard SWG. TF-100 Test Kit w/ Supplemental Borate Test Strips.
    38,473
    Re: Chlorine Odor Question
    Because it reacts with stuff in your nose and creates chloramines I think.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What jason said, if you carefully sniff bleach you will get a fresh smell followed by a bit of the chloramine smell which is the FC from the bleach reacting with the mucus in your nasal passages to form CC.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Fresh Bleach barely has a hint of Chlorine smell.
    Essential Links:
    Jun 2015
    Saunderstown RI
    7
    Thanks guys, that makes sense, and is not something I would have considered. I keep learning new stuff on this site
    Mar 2007
    San Rafael, CA USA
    12,082
    It's not quite as simple as chlorine has no smell. Chlorine does in fact have a smell even if not reacting with any ammonia in your nose to form monochloramine. The odor threshold for both are fairly low and your nose has chemical detectors for chlorine chemicals, not just for monochloramine. As noted in this link and this link, the odor and taste thresholds for various chlorine compounds are as follows:
    Chemical ................. Odor ....... Taste
    Hypochlorous Acid ... 0.28 mg/L .. 0.24 mg/L
    Hypochlorite Ion ...... 0.36 mg/L .. 0.30 mg/L
    Monochloramine ...... 0.65 mg/L .. 0.48 mg/L
    Dichloramine ........... 0.15 mg/L .. 0.13 mg/L
    Nitrogen Trichloride ... 0.02 mg/L ... ?
    Chlorinating liquid and bleach have very high hypochlorite ion concentrations (50,000+ mg/L) so it is not at all surprising that they are readily detected in concentrated form though the amount of such gas that can be emitted is limited since it is a charged ion. The concentration of hypochlorous acid in 8.25% bleach is roughly 2.3 mg/L while in 12.5% it is roughly 0.8 mg/L (it's less because the pH is higher at 12.5 compared to 11.9 for the 8.25% bleach). So even if no hypochlorite ion were outgassed, you would still smell the hypochlorous acid, but it wouldn't be nearly as strong as what you currently smell from hypochlorite ion.
    In pools at the minimum FC/CYA level (7.5% ratio) at a pH near 7.5 the hypochlorous acid and hypochlorite ion concentrations are each around 0.03 mg/L so would generally not be detected. However, the above thresholds are for still water whereas churning the water to volatize the chlorine in the water can certainly get concentrations high enough in air that one can faintly smell the chlorine, mostly of hypochlorous acid.
    This business of "you can't smell chlorine" and "if you can smell chlorine, then it's really chloramine and you need to handle that in your pool" are extrapolated truths mostly coming from the far more extreme situations in high bather-load pools where higher chloramine levels are really producing more dichloramine and very irritating and smelly nitrogen trichloride. These are the "bad pool smell" associated with improperly managed pools especially those with high bather loads. If the chlorine level is too low in such pools then one can build up organic precursors such as urea or build up monochloramine, but what is more likely to happen is that the chlorine level is then raised and reacts with the urea that has built up and that ends up producing the very nasty nitrogen trichloride. However, if the active chlorine level is too high, then this also produces more nitrogen trichloride from chlorine oxidation of ammonia and related compounds. So too much chlorine isn't good either. Managing this using chlorine alone requires elevating the chlorine level at night when no one is in the pool and aerating the water or at least having strong air currents to remove the disinfection by-products before lowering the chlorine level again for the start of the next day. Using non-chlorine techniques would be better with supplemental oxidation or coagulation/filtration to remove organic precursors.
    I think far too much emphasis is placed on "chlorine smell" in residential pools. In some cases where you have higher bather-loads or you have indoor pools with no UV exposure (or UV systems) you can end up with too much urea and get nitrogen trichloride smell, but it doesn't necessarily mean your chlorine level was too low. It just means you are trying to have chlorine oxidize more than it can reasonably handle on its own and one should consider supplemental oxidation systems (e.g. ozone, UV) or enzymes, but for outdoor residential pools these should not normally be necessary. A "clean bleach-like smell" when churning the water in a pool does not mean there is a problem. It's normal. Now when you get out of a pool and you smell your skin then you are likely smelling monochloramine plus maybe some other chloramines because chlorine will continue to react with ammonia from your sweat when you leave the pool and chlorine reacts with ammonia to form monochloramine in under a minute (at our usual FC/CYA levels).
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    chem geek, you simply amaze me.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks, but I see that in this post I showed the same data but from a different source, though made some of the same points. Too bad I forgot about it -- I should have searched first.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    All I know, is I've opened many, many drums of 12% and there is never a smell. Barely detectable to me even with a newly opened bottle of bleach. The odor is so faint it's barely detectable. To me anyway.
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    13,247
    I love threads like this!!
    And I say we collect a voluntary donation to establish a $10,000 book advance fund with a "Draft Chemgeek" campaign for the purposes of cajoling him to write a book! Then TFP can shop it around to publishers. Just a thought.....
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Richard is an invaluable member of this forum, let's not burn him out with book writing duties.
    Essential Links:
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Joy and Chem could collaborate.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2011
    Long Beach, CA
    2,790
    I was thinking the same thing a month ago.
    I hope there is someway that Richard can collect all of his posts and form them into a book so all this knowledge and research can easily be found. I was thinking it should be called something like, "The Pool Bible by Chem Geek".
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Or "Pools Are Easy, Here's How and Why"
    Apr 2015
    South Central PA
    298
    Quote Originally Posted by pabeader View Post
    If telling people that bleach is just liquid chlorine, just do a FAS/DPD test to figure out how much to add boggles people's minds, unfortunately I don't think a book full of explanations on Chem Geeks level will help convince people of the simplicity :-O
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    May 2015
    13,247
    More like "A Dummies Guide To Pool Water Chemistry".
    I'll get the Kickstarter campaign going and track down some publishing houses, you all wrestle Richard to the ground and chain him to a desk and typewriter
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    You mean he isn't already? We better hurry before he gets away.
