I have a pool pump and light for the ingroud pool going into the same box, with two seperate toggles to turn each off. these connect to the main breaker via under ground to the house. the light toggle does not reset the switch on the main breaker. When i try to turn on the pool pump, it trips on the main breaker. Any ideas on how to problem solve this?
THanks!
THanks!
