Thread: Losing pressure
    May 2015
    TN
    312
    Losing pressure
    I have lost about 6 psi in pressure. I have backwashed, cleaned skimmers, etc. I am getting good pressure through the jets still. I do have a small leak in the fitting coming out of the pump going to the filter but it is a very small leak (beads up then drips) and it have been there the majority of the season. I don't think it is the cause. Help please. I started around 115 and it is running about 109 now.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Losing pressure
    What kind of gauge are you using? What units is it measuring? There's just no way a pool pump can generate 115 psi. The filter itself would explode, too.
    I'd suspect the gauge before anything else.
    May 2015
    TN
    312
    Re: Losing pressure
    Sorry I meant 09 and 15. Goes from 0-60 in red and 0-4 in black. Now I am down to 3!! What is wrong??
    The gauge does not go back to 0 when I turn pump off
    Richard320's Avatar
    Jan 2010
    18,984
    Re: Losing pressure
    The flow is still good out the returns? There's no giant air bubble in the pump strainer basket?
    If you can answer yes to both, I'd say the gauge has died. They're not much harder to replace than a lightbulb.
    May 2015
    TN
    312
    Re: Losing pressure
    Yes, everything seems good and good pressure. What gauge would you rec?
    Jun 2014
    Rogers, AR
    424
    Re: Losing pressure
    The one they sell on TFtestkits. It is the best!
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
