Thread: Greetings!
    Aug 2015
    Oakland/NJ
    9
    Greetings!
    Hi All,
    I joined last week and got some great advice in very short order, which was much appreciated.
    I have been a pool owner for a couple of years and have relied upon the knowledge of a friend who has a pool and his family has had a pool for was long as I have known. I have lurked and read several threads and now have finally joined the party.
    My K-2006 test kit arrived earlier this week. After reading an enlightening and very intimidating manual I set forth to conduct my first test. It appeared daunting at first but once I completed it felt like a veil of misinformation had been lifted. The results were enlightening and very different than what I had received at the local store. Today is day one of testing and I feel that I am on the right track to a better pool.
    I have a long way to go and much more to read in Pool School, but and progressing. The responses so far in the forum have been great and I look forward to being part of the community.
    Here are my first set of results:
    - FC 1.4
    - CC 0.2
    - PH 7.4
    - Alk 120
    - Cal 250
    - CYA 75
    DT
    Pool installed in 1996
    22,000 gallons, IG vinyl
    Filter: Hayward DE4820, Pump: Hayward Super Pump
    Just ordered a K-2006, Aquabot Turbo-T R2 Unit, Filled with town well water
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: Greetings!
    75 CYA is a bit high for CYA, but still manageable. You need to get some more FC in there quick. I'd target about 9 if I was in your place.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: Greetings!
    Look at you with those numbers! GREAT JOB!
    So looking at those numbers what do YOU think you should do?
    I will even give you a "cheat link" to use.
    Kim (can you tell I am a teacher?)
    Richard!!!!!!! You beat me to it! I was going to give him a test and you cheated and gave him the answer!
    LOL
    Kim
