Thread: Replacing original weir door
    new-to-poolcare's Avatar
    Aug 2015
    Bellflower, CA
    19
    Hello, I am going to replace the original skimmer weir door with a spring-loaded generic model. Since I cannot find a door with the correct height I thought I'd fill the gap below the replacement door and the bottom of the skimmer housing with a piece of plastic wedged between the sides of the skimmer housing. My question is how do I determine the position of the bottom of the replacement door so that it functions properly. I cannot remember how the original door (that was bolted into the concrete at the bottom of the skimmer housing) looked both with the pump on and off. I hope I have made myself clear. thank you.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Replacing original weir door
    What are your dimensions? I Googled replacement weir doors and it seems as if there are varied sizes out there....?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Sunplay.com has all shapes and sizes, with pictures.
    Pool Skimmer Weirs. Skimmer Weir Doors. Skimmer Weir.
