Results 1 to 13 of 13
Thread: Should you paint PVC plumbing at equipment pad?
    Oct 2014
    San Antonio, TX
    449
    The reason I am wondering is I had some 3/4 pvc from my sprinkler system that I dug up and left sitting in a pile in the yard. I went to discard it yesterday and notice a lot of "burn" spots on the PVC. Curious if this will happen to my pool plumbing.
    If it is a good idea, any particulars about a paint type that should be used?
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    30,431
    Re: Should you paint PVC plumbing at equipment pad?
    Sched 40 pvc is pretty UV resistant. It gets chalky and dull looking but it does not lose too much strength. That said, I think it looks VERY nice painted and gives a very professional look if you do a good job.
    Jul 2014
    Sacramento, CA
    241
    Just beware that if you (or the next owner) need to do additions or repairs later, the paint has to be removed to glue new fittings on. With whatever paint the previous owner used, I was able to get enough off with acetone, but it was a pain to do.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    JM Eagle Short Paper on UV Resistance of PVC
    Note that this will automagically download a small PDF file to your computer.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Here in the "Land of Too Much Sunshine" it's standard to paint all pool plumbing.
    chiefwej
    Apr 2013
    Sacramento, CA
    2,769
    Some California jurisdictions require painting.
    Mar 2015
    Sugar Land , TX
    424
    I noticed my pool equipment ( faces west sun for 7 hours ) was getting real hot!!! Filter felt like it could act like a heater.
    I went to HD and purchased some sail shades
    ShelterLogic 12 ft. x 12 ft. Sand Triangle Heavy Weight Sun Shade Sail-25720 - The Home Depot
    to cover my equipment ( had room to attach from fence to house ). Now my pool equipment is nice and cool and have noticed water temps down 1-2 degrees.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    I can usually tell when a picture of equipment is from Arizona. The PVC is usually damaged from UV. In places that have intense UV, it probably helps. Otherwise, most PVC is not seriously damaged by normal exposure.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I read a study on it. Basically what it said is even if it's left exposed to high levels of UV and it causes that ugly burned look, the damage is very superficial and has little to no effect on its structural integrity. There is a link to the study somewhere around here.
    chiefwej
    Oct 2014
    San Antonio, TX
    449
    Chief, I think agent99 posted an article that confirms your observations.
    Now that I have thought about it,my plumbing has water flowing through it during the heat of the day. Thus the pipe temperature is probably cooler. The dry ones on the ground were very hot when I picked them up.
    All, Thanks for all the comments and advice.
    38,475
    I have found that old discolored PVC can not be cut with shears as it tends to just snap. So it must harden and become more brittle over time. No idea if paint would help or not. Find this to be true even if it was buried.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    I painted my PVC's. It looks much better.
    Divin Dave,
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I agree. In my recent backyard/pool remodel, some dug up PVC (likely buried since 1978...initial pool build) was too brittle to shear with my normal cutters and it snapped and broke instead. Interestingly enough, I just moved a bit further down the pipe and it cut just fine. Go figure. I now house all my pool equipment in a plastic Lifetime shed that I erected as part of the remodel. In addition to protecting it from the elements, it also just looks better not seeing the pool equipment.
    ----Chris----
