Results 1 to 9 of 9
Thread: Salt water test kit
    Jul 2015
    shelter island,ny
    4
    Salt water test kit
    Hello
    I am taking over maintenance of my in-ground 37000 gallon salt water pool with a chlorine generator. I intend on following this site's instructions and the first recommendation is to determine my salinity level and adjust it to be slightly over what is recommended by the generator's manufacturer. My issue is I have been able to find solid recommended test kits on this site but have not been able to locate the ideal salinity tester. Does anyone have a recommendation? Test strips vs drops?
    Thank you
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: Salt water test kit
    Welcome. Pretty hard to beat the Taylor K-1766 drop based test.
    Jul 2015
    shelter island,ny
    4
    Thank you. I just ordered one online.
    Which comprehensive test kit would you recommend out of the five listed on this site
    1 TFTestkits TF-50
    2 Taylor K-2006 /Leslie's 81329
    3 TFTestkits TF-100
    4 Taylor K-2006C
    5 LaMotte 7022
    It states this for #4&5...The 2006C and LaMotte are geared towards VERY frequent testing (commercial) and contain more reagent than you will probably need, but you should consider them if you REALLY like to test a lot.
    also
    Only the TF-100 contains the very handy OTO chlorine test.
    Is this needed?
    Thanks again.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I'd go for the TF-100
    You won't need the OTO chlorine test, but the other half of that is the PH test and you do want that.
    I've used it for a year now and only needed more reagent refills for the chlorine fas-dpd tests.
    Dolphin E10 Cleaning Robot.
    JoyfulNoise's Avatar
    May 2015
    13,171
    Salt water test kit
    Most use the TF-100 as it has reagents stocked in quantities for the tests that you perform the most. The K-2006 is fine too. Add on a SpeedStir and you'll be happy. If you've never done pool testing before, you might find yourself doing a lot of testing in the beginning to "learn" your pool waters behavior. So a TF100 is a good buy.
    As for OTO, I never found it to be very accurate or useful. I prefer the DPD test kit, like the K-1001. Others swear by OTO. So it's a bit subjective. OTO or DPD are really just quick daily tests that you do to make sure chlorine is present and you're in the ballpark of where the FC should be. Accurate values only come from using the DPD-FAS tests found in the TF-100 or K-2006.
    It's all Taylor reagents anyway, so you really can't go wrong.
    Matt
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    SpeedStir...seriously...totally worth it. I'll admit to it appearing gimmicky to me at first but now I find it almost as important as the TF-100 kit. I even made room in my TF-100 kit to store it and I take it out nightly to polish it. LOL!
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Yes do get the speedstir. I went about 3 weeks without one at first and the testing was very tedious by comparison.
    Jul 2015
    shelter island,ny
    4
    Thank you all.
    I have ordered:
    TFTestkits TF-100
    and the all important SpeedStir!
    I look forward to polishing the Speedstir as well!
    Off we go.
    38,237
    Welcome to TFP!!!
    That is the perfect shopping list
