Results 1 to 10 of 10
Thread: Dollar Tree Bleach
    Jul 2011
    Ragley LA
    50
    Dollar Tree Bleach
    Has anyone used Dollar Tree bleach? It's significantly cheaper than Walmart's. It doesn't list any ingredients though. It's 96oz for $1.00 & Walmart's is 121oz for $3.00. Thanks!!
    16,800 gal AG-Vinyl
    Sand Filter
    Hayward SP 1580X15 Power-Flo LX Series 1-1/2 Hp
    Installed: August 2006
    TFT test kit TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Dollar Tree Bleach
    Dollar stores are notorious for having old/expired stock. I don't buy anything that doesn't have the hypochlorite % on the bottle. That stuff is usually 5% or 3% or less. Check the bottle for a manufacturing or expiration date. Many times it's a number like 15186, meaning it was produced on the 186th day of 2015.
    Isolated Spa - 345 Gallons
    Donldson's Avatar
    NW Ohio
    2,916
    I have heard that a good rule of thumb is that if the strength isn't listed then it is probably around 3%. If you want to do an experiment then measure your FC, add this, and then measure again an hour later. Your FC increase will tell you what the strength is.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2011
    Ragley LA
    50
    Ok, thanks y'all.
    16,800 gal AG-Vinyl
    Sand Filter
    TFT test kit TF-100
    Sep 2013
    Charleston, SC
    540
    I agree with the above posted. You can google the product and look at the MSDS page and it will give a range of what the percentage is.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jul 2015
    franklin/tn
    96
    There's a 'bleach prices 2015' thread around here somewhere you should look for Bridgetgirl. Its a great thread to follow and gives you a good idea of the 'lay of the land' including these so-called dollar stores and their old 3% bleach
    33x15' INGROUND pool roughly 14,800 gallons. liner, hayward multiport, sand filter (S-210S), pentair century 3/4hp pump (1081) & 320 automatic chlorinator. skimmer at one end of pool, 2 returns at the other.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    The one in the smaller (96oz) bottle is only like 1% according to the MSDS we were able to find.
    They also have a different one at some DTs that has 128oz. I use it and find it to be at least 6% but sometimes higher. Nobody else agrees with me on this one. For the 128oz. ones the datecode is on the cardboard case they come in. I have a SWG so I don't use it much. Just for those times when I have extra debris or extra people in the pool.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    franklin/tn
    96
    here you go bridget. in fact pabadear is a frequent poster in this thread
    Bleach Prices 2015
    Aug 2015
    Grandy, NC
    135
    I bought some $1 bleach and it took several phone calls (website of distributor said the chlorine concentration was a "trade secret" whaaat? Anyway, they were 2.75%. Used it but bought grocery store bleach.
    Karen
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Jul 2011
    Ragley LA
    50
    Thank you for all the responses! Thanks nyvram for the link!
    16,800 gal AG-Vinyl
    Sand Filter
    TFT test kit TF-100
