Results 1 to 9 of 9
Thread: Discrepancies in Levels for SWG Free Chlorine Numbers
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Today I entered a few days worth of data into Jesse's Graphical Pool Testing Log. It was there that I noticed the target FC level of 10
    for my CYA of 70. I thought according to the CYA/Free Chlorine chart, I should be targeting about 6.
    I'm trying to figure it as I approach the target so I can turn the SWG back on. I will give another day to drop if I should be at 6, or turn it on tomorrow morning of I should be at 10.
    My numbers:
    August 13, 2015 @ 20:40
    Temperature: 74
    pH: 7.4
    Free Chlorine: 11.5
    Combined Chlorine: 0
    Cyanuric Acid: *
    Total Alkalinity: 100
    Calcium Hardness: **
    Sodium Chloride: 2600
    *The last reading for CYA was 70, taken 8/6 before I ran out of reagent. More on order.
    **The last reading for CH was 110, taken 8/11 - not monitored all the time due to the AG vinyl.
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Discrepancies in Levels for SWG Free Chlorine Numbers
    Go directly to the CYA/Chlorine chart in my signature. For a SWG pool with 70 ppm CYA, the FC minimum is 3, target is 5. I'd keep it at 4-5.
    Isolated Spa - 345 Gallons
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    The suggested FC levels in my Graphical Testing log are based on those found in PoolMath. It seems there's a slight discrepancy between PoolMath and the CYA/Chlorine chart.
    I wonder if PoolMath and my spreadsheet should be adjusted to more closely follow the chart?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    38,343
    PoolMath should match the Pool School chart.
    PoolMath just shows the minimum for a SWG pool ... that is all that really matters anyway.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I was more concerned about the "Target" goal which is showing as 10 FC for 70 CYA, when the chart is only showing 5.
    38,343
    Again ... the only thing that matters is staying above the minimum. Every pool will have a different target as their daily consumption will be different
    Mar 2007
    San Rafael, CA USA
    12,082
    The high end of the range is not a Target so does not match the Pool School target column. It shows 10 for 70 ppm CYA regardless of SWG or using Bleach. I'm not sure how the high end of the range was calculated since it does not appear to be a fixed percentage, but it's higher than the Target in Pool School and the Target is not very meaningful anyway. One simply has to always stay at or above the minimum so one's own target for their pool is whatever it takes so that they don't go below the minimum before their next dose of chlorine.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    ChemGeek - That last sentence is very interesting. I've been wondering about that. Thanks for the clarity. Too many times I see folks get too caught up in the numbers and formulas and charts and ...
    This is supposed to be troublefree. All the resources are there to guide us towards understanding our pools. But they are really just guides. The pool is the final judge. Give it want it wants and it will be great.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Quote Originally Posted by chem geek View Post
    Just what I'm looking for. As it drifts into range, I'll be monitoring and adjusting SWG run time during the day.
