Thread: Aquabot Power Supply Issue
    Aug 2015
    White Lake, MI
    1
    Hello everyone,
    I have been a pool owner for three days and I am already messing stuff up, and am hoping somebody could help me out.
    I turned on my Aquabot Turbo this morning and after an hour, I noticed that the bot had stopped moving - he had the power supply chord tangled in his scrubber. I checked the chord and everything was fine, however the light on the power supply will not turn on. I checked the fuse and that was fine, and I also noticed that the "continuous run" like is on. Is there any way to fix this and get my bot running?
    Thank you!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Aquabot Power Supply Issue
    Welcome to the forum!
    I'm sorry I can't be of much help,mbutnimmhopingnambump to your thread will get it seen by someone who may have dealt with this.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I think there is something about this in the owners manual that is on the aquabot web page, you may want to download a PDF of it (I know it is better than the manual that came in the box for my aquabot turbo T) I just can't recall exactly what it says about the light being on.
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    Sounds like the drive motor may have burned out - I had similar issue couple of years ago, when it happened to me, and I was convinced that it was the power supply. Ended up being the motor. Based on what you are describing - the cable being stuck in the brushes, it does seem more likely than not that it is what happened to you. There is a website, Aquabot Troubleshooting that will walk you through how to check the motor vs the power supply.
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
