Thread: Sand filter
    May 2015
    Moline, IL
    31
    Sand filter
    my sand filter says: Effective filtration area 3.14ft2 Filtration rate 20 gpm/ft2 filtration and back wash design flow rate 62 gpm Does this mean that it filters 62 gallons a min?
    38,235
    Re: Sand filter
    No. The rate it will filter depends on your pump size. Generally filters list the maximum flow rate that you should use . But in reality the lower the flow rate the better the filter will work.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: Sand filter
    Your math indicates that the filter is CAPABLE of filtering at that rate I think. Just depends on the flow rate it is being fed. Any pump higher than that is a waste. Again, a little slower is better.
    30,395
    Re: Sand filter
    So if I am reading brandon1's post correctly he has 3.14 sq ft of filtration area and his acceptable (max, sort of) rate is 20 gpm x 3.14 for 62.8 gpm. Is that right?
    That also means that any pump pushing more than 62 gpm into that filter is overkill, too, right?
    Apr 2010
    East Texas
    9,552
    Re: Sand filter
    That's sure what I think!
    38,235
    Re: Sand filter
    The 63 GPM might be the design limit for public applications. I know some filters give a rating that gives the maximum allowed rates for public pool code. Usually a private pool can run higher flow rates. But again, slower is usually better.
