Results 1 to 18 of 18
Thread: added pool sock to my pump basket..raised filter pressure 1psi
    Jul 2015
    franklin/tn
    96
    is that normal? i am hoping this helps to keep the system running better but i don't want to put additional strain on the filter and pump.
    thanks!
    33x15' INGROUND pool roughly 14,800 gallons. liner, hayward multiport, sand filter (S-210S), pentair century 3/4hp pump (1081) & 320 automatic chlorinator. skimmer at one end of pool, 2 returns at the other.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: added pool sock to my pump basket..raised filter pressure 1psi
    It should be fine, just check it more often. Socks catch small particles quickly. I love using filter socks.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    That's seems odd to me. Is the pressure gauge on the pump or the filter?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Tempe, AZ
    194
    Quote Originally Posted by pabeader View Post
    Agreed - you'd think adding more restriction on the vacuum side would reduce pump pressure. I wonder if it was a solid before/after comparison? Maybe the basket was already dirty?
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    Jul 2015
    franklin/tn
    96
    Sorry the pressure gauge is on the sand filter.. Attached to the multiport.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    so it really should have went down, not up. Interesting.
    38,271
    It is generally not recommended to use the skimmer sock in the pump basket. You put yourself at risk of starving the pump of water if it gets clogged.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    the sock/strainer should go in the skimmer NOT the pump Basket!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2015
    franklin/tn
    96
    oops, i guess i need to move it.
    i thought the idea was to put it around the pump basket/skimmer because its notorious for getting tiny little pebbles embedded in the screen. i took it out and cleaned it 100% today before i put the sock on it.
    i thought the point was to prevent small pebbles from vacuuming making it into the impeller.
    so i should move it from the pump basket to the pool?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Do you have a bottom drain?
    If all you have is a skimmer and no bottom drain, then what is the difference between the skimmer and the pump basket?
    If you have a bottom drain and a skimmer, then if you put the sock in the skimmer and it plugs up, the water can still go through the bottom drain.
    Jul 2015
    franklin/tn
    96
    i have both.
    skimmer catches most debris..until i plug the vac in. To do that I remove the skimmer basket completely, plug the hose into the hole underneath where the skimmer was and divert the pressure from the bottom drain to the skimmer so the vac has enough pressure to pick up the small rocks that always seem to get into the pool.
    the bottom drain i crank up during the slam to help pull out debris/algae i stir up on the bottom of the pool.
    i have to open the pump drain each time i vac (if there's alot of debris) because everything gets sucked right into that 'backup' skimmer.
    I have a polaris fitting on the side of the pool but the pool guy said it was never set up.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    My skimmer is a little different. I leave the basket in while I'm vacuuming. But I'm inground. So, here's my suggestion for you. Sock in pump basket only while vacuuming. Then back to skimmer for normal use.
    You might want to add the bottom drain to your sig???
    Jul 2015
    franklin/tn
    96
    Ok I will add that. I have just a basic in ground vinyl liner pool.
    Jul 2015
    Tempe, AZ
    194
    You could try something like a leaf canister in your vacuum line as a pre-filter. I have one connected to my cleaner line and it grabs most of the leaves and such.
    http://www.amazon.com/Hayward-Naviga.../dp/B000EW6EGI
    Even try a sock in that if pressures don't get cut too much. I've considered but never attempted it.
    Jun 2014
    Long Island, NY
    340
    I would think the sock in the pump basket is a accident waiting to happen. if your concerned about stuff getting to/thru the pump while you Vac, you can get a leaf catcher inline and put the sock/strainer in that
    Edit, Dam Cinic, your fast
    38,271
    Definitely should be using a leaf canister with a suction cleaner or vacuum, especially if your vacuum is not running through the skimmer basket.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I misunderstood your post at first. I wouldn't put a sock on the pump basket. I put mine on the skimmer basket and in the leaf bag of my Polaris. Doing that means I haven't had to vacuum even once this season and my pump pressure has never gone up over its clean pressure. I pump to waste when we have heavy rain, but I haven't had to backwash since last year. Skimmer socks rock.
    Jul 2015
    Kentucky
    1,125
    I have an AG too, and I vacuum through the skimmer basket using a Skim-Vac plate over top of the skimmer basket, not the pump basket.
    Here is an article I wrote about the benefits of using a knee high panty hose which is the exact same concept of using a skimmer sock, etc. in the Skimmer basket to help clean your pool. (A knee high, skimmer sock, hair net, etc. all of which were mentioned as suggestions in the comments of the article will accomplish the same goal). But I tend to agree with the others that placing anything that could become blocked, or dislodged in the pump basket is IMO taking a very high risk of tearing up your pump. Anyway here is the article if you'd like to read it, and I'd recommend moving your "skimmer sock" back up to the skimmer basket. I hope this helps, and have a nice day.
    http://www.troublefreepool.com/threa...905#post884905
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
