Thread: chemistry of closed/winterized pools
    Mar 2009
    Charlotte, NC
    539
    As I read posts, I see mention of adding chemicals when the cover is on.
    Am I supposed to be testing the chemistry of the water year round? Can't w/out the pump running, right?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: chemistry of closed/winterized pools
    Hi Johnny (sorry for the poor joke in your into post )
    Testing the water while the cover is on in the winter isn't really necessary if you've kept up on the chemistry all summer and properly closed. However, some folks still find they'll open to a green pool, so those folks should peel back a corner of the cover and test the water 1X/ month while the pool is closed and dose accordingly. If they choose to dose the pool, they usually use a submersible pump to provide circulation.
    This is the quick explanation of it - if you've further ?s, just ask them
    Luv& Luk
    -Ted
    Mar 2009
    Charlotte, NC
    539
    "they usually use a submersible pump to provide circulation."
    So no care to any small amount of water in the pipes or skimmer.
    Like what an electrical cord & a garden hose is attached to to drain an area, but in this case leave the hose in the pool?
    This time next year you guys will have me nealy a pro at this. So my guess is I ought to start testing 1 month before opening, while the temperature is quite cold, & then balancing upon opening will be a snap- just a guess. Accurate or no?
    Never too many jokes; never a "poor" joke if they are about me- no worries.
    Thanks
    Mar 2007
    4,160
    A properly closed pool would have no water in the pipes (but would have some anti-freeze) and the skimmer would have the line clear of water, some anti-freeze and some sort of compressible material in the body of the skimmer housing to absorb ice expansion.
    If that's the type of submersible pump you have, it will do the trick with the outflow hose directed back into the pool water.
    To be honest, if I were you - I wouldn't worry about it at this point After you truly open the pool we can talk you through any green nasties you may see (I also said that you do this if you've kept up on the chems the season before and properly closed the pool).
    I appreciate that you are learning a lot here and are wanting to DO something with the pool to help it be ready to swim in... but 1 major part of BBB is POP (pool owner patience) - -- have yourself a sup of POP and deal with the pool when it comes time to open it
    Luv& Luk
    -Ted
