Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: First time pool owner with SWG
    Aug 2015
    TX
    66
    Hi all. I've been getting help in the other forum with my readings and such, but have a question to ask in here.
    I was was going to have someone come over and show me how to use the equipment, but at $150 for one hour, I decided to pass on that.
    i have the manuals for all the equipment, but here's my main question.
    how long should the SWG be running? The previous owners have two timers set on the equipment and I am assuming the SWG is tied into the pump. The pump runs on high from 7 am-11am and I am guessing that is when the SWG is also running. I have yet to be able to confirm that because I'm at work during those hours.
    I know now it's working at some point because I have salt in the pool and chlorine...although the FC is only 1.5 right now. I have tested FC in the late afternoons when the sun is off the pool.
    im assuming the previous owner had the timers set for a reason and knew what he was doing; however, I would like to understand myself. Maybe the settings need to be tweaked.
    16,065 gallons IG, gunite, pump: Jandy 2.0 hp 2-speed, filter: Jandy 60 sq. ft. D.E. filter, automatic pool cleaner: Polaris 280, chlorination: Jancy Aquapure electronic salt water chlorinator
    Jun 2014
    15,093
    Re: First time pool owner with SWG
    Hello and welcome to TFP! There are MANY SWG owners here (I'm not one ), so you can expect several responses. IN the meantime, I wanted to ensure you saw/had the two TFP pages below:
    SWGs: Pool School - Salt Water Chlorine Generators
    SWG water balance: Pool School - Water Balance for SWGs
    Welcome to TFP!
    Aug 2015
    TX
    66
    Thank you! I HAVE read everything I can get my hands on, and I have the general idea of what it's supposed to be doing, but I'm just looking for some extra insight and help. I know that the percentage and run times will vary, but I need a general idea of where to start.
    Jun 2015
    Charlotte, NC.
    82
    Pictures of your equipment pad and closeups of the SWG and control panel would help us be more specific. In general, your SWG is most probably set to run when your pump runs, and depending on flow may run only on high, or may run whenever your pump is running. It should also have a percentage set (i.e. 50%) which means it only produces chlorine 50% of the time the pump is on. bumping the percentage is the easiest way to raise chlorine production, but if its at 100 then you would need to bump pump run time, and maybe bump it when its running on full.
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Aug 2015
    TX
    66
    Let's see if these work.
    [img] IMG_3517.JPG - Google Drive [\img]
    [img] IMG_3516.JPG - Google Drive [\img]
    [img] IMG_3519.JPG - Google Drive [\img]
    [img] IMG_3520.JPG - Google Drive [\img]
    [img] IMG_3523.JPG - Google Drive [\img]
    [img] IMG_3525.JPG - Google Drive [\img]
    [img] IMG_3524.JPG - Google Drive [\img]
    the one and only time I saw the SWG on it was at 85%.
    30,419
    RuthN,
    Everything we teach begins and ends with test results. If you will post your current CYA and FC, we can help make a guess at how to set your run time. We really need to see all your test results to make educated opinions rather than just stabbing in the dark.
    Jun 2015
    Charlotte, NC.
    82
    Someone with the Jandy 2.0 HP 2 peed will have to answer about if the low speed is enough to trigger the flow sensor in the SWG. Since the aquapur is set at 80% now, you will have to increase the run time to up production.
    It's also OK to manually turn the equipment on when you are there so you can see how it's all working. Turn the Jandy pump on low and see if the SWG shows as outputting. Either way, to bump chlorine production you will have to bump run time of the pump.
    - Matrioux
    Jun 2011
    Long Beach, CA
    2,784
    To answer your question the SWG needs to run as long as it needs to and at a high enough output percentage in order to make enough chlorine for your pool. With that said, we need to see all of the pools chem levels:
    FC
    CC
    CYA
    pH
    TA
    CH
    Without knowing these numbers we have no idea if your pool is balanced or not. The amount of CYA in the pool plays a major factor in how much chlorine needs to be in the pool. One thing that I do know is that we can improve the SWG performance if the pool is balanced per TFP suggestions, Water Balance for SWCGs.
    Aug 2015
    TX
    66
    Test results from 2 days ago -
    I did testing again today. The only thing I've done is added conditioner. Some of these numbers are ridiculous. I don't know how to use the equipment....swg, etc. There's a timer and I haven't changed any settings since I moved in. They are the previous owners.
    Here are my numbers
    FC. 1.5
    CC .5
    TC. 2.0
    CH. 50
    TA. 250
    CYA. 20
    ph: 7.8
    Test was done in late afternoon after shade had hit the pool. Pool sits in direct sunlight from approximately 9 am to 4 pm. I have been putting in conditioner (I bought an 8 lb bucket) since Sunday....that's why I'm only testing every two days right now.
    30,419
    Now that's helpful. Your CYA is too low. Bring your CYA to 60 ppm and don't touch a thing on your SWG. Your FC is being consumed too rapidly by the sun and increased CYA will help preserve it. You may have to reduce the percentage on your SWG but don't do it until you observe FC climbing.
    Aug 2015
    TX
    66
    I THINK the SWG is running when the pump is on high from 7 am to 10am. I have YET to verify that since I'm not home during those hours. I'm hoping to verify that tomorrow morning. Beyond that, I will be testing the water again tonight since it's been 2 days and I've added more conditioner. Hopefully there is an increase in CYA.
    Jun 2011
    Long Beach, CA
    2,784
    The CYA will be in there but it might not show up on a test for a week. Test the FC daily and after a week test the CYA. From your test results there is no need to rush things. If you want, it wouldn't harm the pool to add a gallon of bleach to help boost the FC a bit.
    30,419
    How much? Conditioner is CYA so there will be an increase but what was your dosage?
    Aug 2015
    TX
    66
    I have an 8 lb tub of dry conditioner. I've been doing a sock full in both skimmers. They take about 48 hours to dissolve. I've put approximately 3 lbs in since Saturday.
    Jun 2014
    15,093
    If my calculator numbers are correct, based on your pool volume, it would take 5lb 6oz of granular stabilizer to go from your first CYA of 20 to the recommended 60. So if you've only put-in about 3 lbs so far, you can still add 2 more pounds.
    Jun 2011
    Long Beach, CA
    2,784
    Three pounds of CYA should bring it up to 40 as three pounds should only add 20 points to the CYA. To be safe, wait the full week to see how close the CYA is to 40. If you wait the week and it measures 40 then you can add the rest of the container which should raise it close to 80.
    You can use PoolMath to make all these calculations.
    Aug 2015
    TX
    66
    New readings based upon a sample taken from the part of the pool that had been shaded for 3 hours:
    ph 7.8
    FC-2.0
    CC-0
    TC-2.0
    CH-125
    TA-150
    CYA-40
    looks like conditioner is starting to work.
    Jun 2014
    15,093
    CYA starting to rise for you is a good thing. Now a couple other things to watch:
    - Don't let Ph get any higher than 7.8. You can use muriatic acid to lower back down to the mid-7s. It will also lower TA as well.
    - Keep working on increasing the FC to at least an FC of 4. Going to even 5-6 won't hurt right now either since your FC has been low for a while. If you're still trying to dial-in that SWG, you can use a little regular bleach to assist in raising the FC a little.
    Looks like you are doing better though. If the condition of your water clarity should change, let us know.
    Aug 2015
    TX
    66
    Water clarity is still great. I'm a little concerned about the TA though.
  20. Back To Top    #20
    Jun 2014
    15,093
    Here is a great TFP page on that very subject: Pool School - Lower Total Alkalinity
