Thread: am I going to have to replace my pump?
    Aug 2008
    Las Vegas, NV
    116
    I went out to backwash this morning and everything went as usual until I turned the pump off and switched to rinse. When I turned the pump back on, the motor made a mrrrrrr (or whiring sound) and did not rinse. I turned it off and went back to backwash and same thing. I quickly turned it off and the pump was hot to the touch. Is my motor burnt up? It's a Hayward II Super Pump 3/4 HP. Do you think this is going to have to replaced?
    I'm so bummed. My pool is looking great and my water balance was perfect yesterday! I've sent an email to the landlord and hopefully he'll get someone over here to look at it soon. Is there anything I need to do in the meantime?
    Pam
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: am I going to have to replace my pump?
    If the shaft of the motor spins freely by hand you might be able to get away with replacing the capacitor(s). They're black cylinders, about the size of D-cell batteries, and are housed either under the back plate where your wires connect or under a bulging plate on the side of the motor. If you have a pic handy I'll point them out for you.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Sphshex had a good idea, and it's pretty easy to replace. You did not share how old this pump is, though. As a renter, you probably don't know, but it may just have given up the ghost after long and faithful service!
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Aug 2008
    Las Vegas, NV
    116
    Thanks guys. I talked to my landlord and he said he would call the pool guy out to fix it today. I went out to check on it this morning and it started working. Maybe it will hold up for a while longer. Looks like we're going to be moving before too much longer....UGGG...hope we can find a house with a pool. (We'll be buying next time)
    Pam
