Results 1 to 7 of 7
Thread: New pool owner, first time SLAMing, am I doing it right?
    ducky's Avatar
    Aug 2015
    Chester VA
    2
    This is my first post. I finally registered on the site, but I've been reading for some time now, thanks to some good friends at work who directed me here and told me what test kit to get! I am currently fighting algae using the SLAM process, but I'm not sure if I'm doing it right. Progress seems very slow. I started SLAM on Sunday, but since I work Mon-Fri, I am only able to test water in the morning before work and in the evening after work (roughly 10 hours). Today is Thursday, and the water is still green, but it does appear to be a lighter green. Is this normal? The CYA test each day is between 40-50, and I use pool math to add chlorine each day to keep my FC at 20-22. I test every morning and every evening, and the FC is never below 18, so I just keep adding chlorine (per the pool math) to get it back up to 20-22. I brush the sides of the pool every evening, and clean the cartridge every day. Is this what I'm supposed to be doing, or am I missing something?
    10,500 gal, 22'X52" PolyGroup Pro Series AG Round Frame Pool, Vinyl Liner, FSF2000 Filter System w/ F200C Pump, Cartridge Filter, TF-100 Test Kit
    38,521
    Re: New pool owner, first time SLAMing, am I doing it right?
    Welcome to TFP!
    Sounds like you are doing it right.
    No need to keep testing the CYA, it should not change.
    Try to test in the morning, after work and before bed.
    Aug 2014
    Northern IL
    4,615
    Clean your skimmer with a toothbrush, inside and out. Clean under your steps, removing them if possible. Scrub every hidey-hole.
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    I had the same problem when I opened this year green algae and bad, I mean a neglected green pond bad. I followed the instructions as you are doing now. It took a long time to clear, nearly a month but it is so beautiful now it almost does not look real. Keep up the good work and soon you will have the same result !
    Vinyl liner in ground. Pool volume 27,000 Gal. Sand filter. Pump runs 365 days a year 24/7 (Hayward pro series model S220T 1 HP. motor). Taylor K 2006 test kit. I use the BBB way found here at TFP. The only thing I buy from the pool store is CYA.
    Sep 2013
    Connecticut
    728
    It is normal for progress to be slower if you can only check on the pool a few times daily. You can try running just a bit higher FC levels. The usual recommendation when your CYA measurement is between two numbers is to round up, which means you should SLAM for a CYA of 50. If you aim to never let FC go below 20, you're more likely to keep the algae on the ropes, and eliminate it more quickly.
    If you can squeeze in one additional pool visit before bed, that may help, as will more frequent checks during days off from work.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    ducky's Avatar
    Aug 2015
    Chester VA
    2
    Thanks so much everyone for the advice! MarianParoo, I did remove the ladder and there was green gunk under the bottom of the legs. I will continue SLAMing and testing...it's the weekend now, so I will be able to devote more time to it. I'll be scrubbing and vacuuming a lot more. And I will target a higher FC as singingpond suggested. You all have given me hope, thanks again. I am determined to beat this!
    Aug 2014
    Northern IL
    4,615
    You can and WILL do this, and we are here to help!
    Green gunk? Oh boy! Remember to check-out that skimmer and the returns with a toothbrush! (Hahaha, Duraleigh!!! -inside joke there...)
