Thread: Backfilling an above ground pool
    Jul 2015
    Valpo IN
    2
    I asked for the opinion of the pool installer on what was the best for backfilling the void left when digging the extra 2' on the perimeter of the pool and they said to "just use the dirt". I don't know if I agree or like doing so considering it has a decent amount of gravel and clay. I also asked if I should use a foam barrier and their response was that it would just hold the moisture against the side and cause it to rust sooner. Any other opinions or preferences would be much appreciated! It is approximately 28-30" deep at the deepest part of the dig to pretty level ground. Thanks ahead of time, for your time!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Backfilling an above ground pool
    We're assuming this is a partially buried steel wall above ground pool? If so, is it warrantied for burial if you care? Welcome.
    Jul 2015
    Valpo IN
    2
    I didn't even check to see if it was warrantied for partial burial. I am a 100% newbie for the entire pool thing! Definitely overwhelmed
