Results 1 to 8 of 8
Thread: What Chlorine?
    Aug 2015
    Wheatfield, NY
    57
    What Chlorine?
    I have an issue with high CYA. Just read the book on the Dichlor I use and it says includes stabilizer. What CL should I use to keep the FC correct but not add more stabilizer? I would prefer a powder and not have deal with liquid bottles.
    30,411
    Re: What Chlorine?
    Calcium Hypochlorite is commonly used but it comes with some baggage. If your CH is high already, it is a definite no-no. Even if your CH is not high Cal Hypo can easily cloud a pool and take some time to clear. It does not dissolve readily so it can lay on your pool floor for a while.
    It continually adds CH to your pool until your CH is too high.
    Over and over, we preach that liquid chlorine is the absolute best and purest way to deliver chlorine to your pool........unless you get an swg.
    Jan 2012
    'burbs of Augusta, Georgia
    7,301
    Re: What Chlorine?
    The only other powder that doesn't have CYA in it has Calcium instead. Can your pool stand to have calcium added?
    Liquid chlorine adds only chlorine and a teeny bit of salt (not that you'd probably ever notice) so its the best bet, unless you wanted to use a Salt Water Chlorine Generator (SWG). Those are pretty darn convenient and no jug lugging!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: What Chlorine?
    Jug lugging. That sounds like some new official jargon!
    Sep 2013
    Connecticut
    728
    Re: What Chlorine?
    Quote Originally Posted by GypsmJim View Post
    None of us use bleach because we love to lug around heavy weights or get a kick out of the occasional bleach spot on our clothes
    We do it because the convenient solid chlorine products all carry unwelcome baggage with them. That is a fact of chemistry, not just somebody's arbitrary marketing decision (i.e. to get a solid material containing chlorine, you have to have another chemical in each molecule - they aren't just mixing two piles of dry powder together and packaging the result).
    I believe there is also a lithium hypochlorite product out there, but not much discussed - it is apparently very expensive.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: What Chlorine?
    RE: Jug lugging
    Really no big deal. I go out to the pool daily anyway to test and view my clear water
    Once the pool is stabilized most people add a portion of a jug daily, how much depends on CYA & strength of bleach/Liquid Chlorine. In my case it's about a half to a third of a gallon a day. I guess the only lugging i do is buying 3-4 case of LC to have a 4-6 week supply. I'm now a certified Bleach Bum.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Re: What Chlorine?
    Quote Originally Posted by EVChargeGuy View Post
    Sig worthy! I'm so stealing that when we get our pool. Haha.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Donldson's Avatar
    NW Ohio
    2,888
    Re: What Chlorine?
    Quote Originally Posted by singingpond View Post
    Yep, Li-hypo is technically a viable solution. It is a solid form of chlorine that does not add calcium or CYA to the water. Pound for pound it is weaker than even the cheapest cal-hypo (4.2ppm/lb/10,000 gallons vs 5.7ppm/lb/10,000 gallons for 48% cal-hypo) and costs twice as much. So it is by far the least cost efficient option for chlorinating your pool. An SWG would be a better option.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
