Thread: Watercolor changed on my new pool help!
    Aug 2015
    NJ
    5
    Just had a new pool installed this month. Not fully completed yet just waiting on the ground to settle for concrete install. Purchased the sandstone tan liner, went to see it in person and loved it because it has a nice Caribbean turquoise blue water. Fill the pool and it turned turquoise but was dirty. Pool company came by to start a filter and added chemicals for the first time. It changed the water color to blue. Looks nice but not the color it supposed to be. If you look into the bottom of the pool when we first filled it without chemicals (with city water from the fire department) you can see the main drains and they appeared crisp white. Once chemicals were added water is blue and main drains appear blue in color. Very weird any advice is greatly appreciated.
    Chemicals that were put in were calcium, And heavy-duty shock of some sort. They said we could not use the pool for 48 hours and that they only use this chemical when opening the pool for the first time. Sorry I forgot the name. And then they turned on the frog system. Here are some of the before-and-after pictures. The pool is a little dirty in the before pictures from doing backfilling and leaves falling it. Thank you! [IMG]http://images.tapatalk-cdn.com/15/08/13/
    fabc95217e748ae76ba8bca0982243af.jpg[/IMG]
    28,000 Gallon Inground Vinyl Liner Pool (Sandstone)
    Hayward Sand Filter 2HP Pump with Frog Mineral System
    August 2015 install, testing w/ Aqua Chek 7, Pool filled with City Water Fire Department
    Dolphin Supreme M500, Haward Prologic LED lights, Sun Deck and Swim Out
    Danyale :)
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: Watercolor changed on my new pool help!
    It's normal for city water to appear green at first then turn blue..sometimes over night.
    Dolphin E10 Cleaning Robot.
    Aug 2014
    Houston tx
    2,524
    I'm a bit confused. No surprise here, huh! Lol! You do want the water to be turquoise green and not blue correct? Maybe it will just take a few days for it to be the right color.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Congrats on the new pool!
    Give the water several days to a week to settle down and see how the color looks.
    We are not big fans of mineral systems at TFP. More here, Alternative sanitizers and pools--The Truth!!
    More on test kits here, Pool School - Test Kits Compared
    And managing your pool water here, Pool School - ABCs of Pool Water Chemistry
    38,272
    Lots of things off here, most were covered already.
    No need to ever add calcium to a vinyl pool.
    And certainly not a good idea to be adding metal to your pool. That can certainly stain your pool and turn your hair green.
    30,415
    What's up with this thread? There was a picture of a green pool here earlier. Danyale717, can you clarify what you are asking?
