Thread: Adding a drainpan under my sand filter...
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    Every time I have to open my filter to replace a lateral, or check for tunneling, I get leaks at all point of connection coming out of my filter. Eventually, they either fill in with grease, grime or grit and seal up, or I apply a little silicone sealant to the threads. I have 2 pvc unions on the in and out line, and these are the usual culprits. Also, the retaining ring under the multiport like to bleed too, but I usually put sealant around that.
    Has anyone ever set their filter inside a drainpan, similar to what you would use under a hot water heater, to catch any water that would leak out and return by temporary hose back to the pool? I think next time I have to break down my filter I'm gonna try this, was wondering if anyone else has had this experience.
    I'm leak-free now, had to loosen the last union and hand-tighten, then gradually tighten with rubber-strap wrench until drip stopped.
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Frog inline chlorinator
    Town water
    30,426
    Re: Adding a drainpan under my sand filter...
    That's not a bad plan but i have been fortunate not to open my filter except once in 9 years for a repair.
    That said, my filter is inside a garage so a deep cleaning and inspection of the sand makes a real mess. being able to even capture that water in a drain pan and get it outside is worth thinking about
