Thread: IGP Spa jet venturi adjustment.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hi, all.
    Quick question. I have a IGP with a spa attached. I have five jets. Four of the five produce a venturi effect, but the one by the step does not when the blower is off. Is there any way to adjust this so it also has a venturi effect? I have tried adjusting the jet tube (screwing in and out various amounts), with no success on this particular jet.
    And ideas?
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: IGP Spa jet venturi adjustment.
    If you have a blower on the air pipe and it is not running, it isn't a surprise that one of the jets isn't working. They really aren't designed to do that. The blower restricts air flow unless it is on so if you want to try the jets without the blower, remove the blower from the air pipe.
    Even then, it isn't guaranteed to work unless the spa was designed to work without a blower and many PBs don't know how to do this.
    Mark
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Interesting.....I will try that this weekend. If it works, I'm sure I can create a cap with some holes it. Thanks for the suggestion!
