Results 1 to 8 of 8
Thread: New pool owner
    Aug 2015
    Willow Spring, North Carolina
    2
    New pool owner
    I have a 5300 gal. above ground pool. Cartridge filter. We live in North Carolina. Hot and sunny!!
    It was put up about 2 months ago. We filled it (ugh). Played in it for a few weeks. We were using chlorine pucks. It got green then it got very green. We started adding algicide etc...
    About a week ago a neighbor told us about this site. We ordered the TF100, a new cartridge filter system. Both came today but we had already started with the bleach right away.
    Test results today:
    PH 7.5
    FC 12.5
    CC 2.0
    CYA--0 very clear all the way to the top.
    Water looks milky/ cloudy filter changed daily and is red/brownish. I think we are at the point where we just filter 24/7 until it clears up and also add stabilizer to bring up the CYA checking the chlorine levels and adding daily as needed. Does this seem right?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Re: New pool owner
    Welcome to TFP Once you get the pump running 24/7, since your FC is already at 12.5 start adding CYA (Stabilizer) to get it up to at least 20ppm Here is the CYA chart http://www.troublefreepool.com/conte...art-slam-shock. Once your CYA reaches 20 you will be at shock level http://www.troublefreepool.com/conte...tain-shockingl
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: New pool owner
    Stop with the agaecide, thank your neighbor, and continue with the SLAM!
    May 2014
    Lewisberry, PA
    93
    Re: New pool owner
    Don't forget that it will take a couple weeks for you to test the stabilizer accurately. It's best to go easy adding it until you get a feel for where it actually is. Unless you like draining your pool........
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New pool owner
    Good advice. CYA/stabilizer will show up on the cya test after 1 week.
    Aug 2014
    Northern IL
    4,615
    Re: New pool owner
    Welcome, Bill! We will be here to help. No question is too silly! Good luck with your SLAM. Plan on adding chlorine more than once a day until your pool is perfect.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: New pool owner
    like woodyp said "stop the algaecide" that's probably why you're cloudy.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    2
    Re: New pool owner
    Thanks everyone. Slamming away.
    15" 5300 gallon above ground Intex
    2500 gph cartridge filter.
