Results 1 to 7 of 7
Thread: Double Your Pleasure
    It's always fun to have 2 minor problems going at once!
    Pool light is not working. I replaced the 20 amp GFI breaker and Light switch. GFI breaker will not reset and "throws" to off every time. Any ideas what to try next?? Pool light could possibly be bad but it hasn't been use but very few hours since installation in 2009. Would a bad bulb cause the GFI to break soon as it's set??
    Added DE to sand filter after deep cleaning twice and now DE is showing up on pool bottom... Multiport valve is new and I'm suspecting bad laterals but know of no way to be sure except removing sand and checking. If I remove sand I figure I might as well change laterals either way since half the work is already done. Am I on the right track with this problem??
    Thanks for the help. I knew nothing of pool maintenance until I found TFP!!
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    22,553
    Re: Double Your Pleasure
    A bad bulb can cause the gfci to trip as soon as it's energized. Moisture or incorrect wiring in the junction box will also cause it. Have you opened up the junction box and looked at it?
    How much DE did you add?
    DE is fine enough to go right through a sand filter lateral slit. You're depending on the sand bed to stop it and if you add too much it will go right into the pool.
    Also did you use filter DE or garden DE? There's a difference.
    Jun 2015
    Wildomar, California
    423
    A bad bulb or water in the light will trip the GFI. If your multiport valve is good, and you added DE, then you probably have a broken lateral(s) or you have channeling in your sand. The curious thing is that a broken lateral allows DE and sand to return to the pool.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I had water getting into the junction box that caused the breaker to trip.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Thanks to all!!
    I added approx. 3 cups pool DE, I'm thinking I added too much. I've had no rain lately but am planning on vacuuming to waste soon as I get some rain to get rid of the excess DE.
    The pool light is 6 years old with little use but I expect moisture has finally leaked in. Junction box and switch is dry. I'll try replacing light and seal.
    22,553
    3 cups is a lot for that filter. You can put a skimmer sock in the skimmer and vacuum it up to get rid of it.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Did you wire up the GFCI breaker correctly? The coiled white neutral wire ties to the neutral bar in the panel and all the neutrals from the equipment being protected tie into the breaker itself along with the hot wire. There are two connection points on the GFCI breaker: one for black/hot and one for white (neutral).
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
