Thread: New pump and filter suggestions for Bestway pool wanted
    Aug 2015
    Morongo Valley, CA
    2
    Question New pump and filter suggestions for Bestway pool wanted
    Post split from Intex Bestway /FlowClear pump hose interchangeable? Zea3
    I just bought my first above ground pool, Bestway 12' x 48". I want to switch to a sand filter pump set up but so many of them I see are advertised as being for a much larger pool than I have. Should I be concerned about getting a pump that that's for a pool that slightly bigger than mine?
    Aug 2015
    Morongo Valley, CA
    2
    Sand filter size limits
    I just installed a Bestway 12' x 48" above ground pool and want to replace the stock filter system with sand filter. I keep seeing the number of gallons in size limitations for the filters for sale. Should I be concerned about getting a sand filter that is rated for a pool slightly larger than mine? My pool is only around 2,700 gallons so most of the filters are advertised as being for a much larger pools. Any recommendations? Thanks!
    38,354
    Re: Sand filter size limits
    Welcome to TFP!
    There is no issue going with a larger and filter and pump. The bigger the filter, the less you have to clean it. It is possible for the pump to be too small for a filter, but you would have to get a pretty extreme mismatch to have an issue.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,542
    I've got a dollar that says a bigger pool is in your future, so go bigger on the pump/filter now and you won't have to buy a new one next year.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
