Thread: Something is wrong
    Aug 2015
    Easton, PA
    4
    Unhappy Something is wrong
    I have SWG pool. 25k gallon. Just tested levels
    FC-1.5
    TA-120
    PH-8
    Calcium-200
    CYA:30-50
    Had a heavy rain a couple of days ago, so added some shock. PH a little high, so added some muriatic acid right after shock. A couple of minutes later I noticed a dark "stain" at the bottom of the pool. It followed the path I poured the shock and acid. I tried brushing the stain, but nothing. It appears that the shock and acid had a reaction and settled at the bottom of the pool. I have added the shock and acid before in this manner and have not had an issue. Why would this happen? Will the stain go away? Is the pool safe to swim in? Very concerned about this. It is an in ground, Gunite pool. Any insight is greatly appreciated!!!
    Pool size: 25k gallon
    Inground pool
    Gunite
    aqua rite SWG
    38,242
    Re: Something is wrong
    Welcome to TFP!
    What is shock?
    How are you testing?
    Aug 2015
    Easton, PA
    4
    Shock- HTH brand (47.6% calcium hypochlorite)
    Tester - used HTH 6 way test strip and Taylor DPD chlorine tester. Both read ~1.5 ppm.
    I just read something that suggested that calcium hypochlorite mixing with metal (copper or iron) could turn a pool surface bottom. Could this be the issue? I have never had an issue with metal in my pool before.
    Inground pool
    Gunite
    aqua rite SWG
    Jan 2012
    'burbs of Augusta, Georgia
    7,260
    Re: Stain-Ever put algaecide in the pool?
    Why is your FC so low? It should be higher whether your CYA is 30, 40 or 50. What is is exactly?
    30,403
    Well, it's 20-20 hindsight but NEVER add chemistry like that. Always add it in front of a return (pump running).
    So the Cal-hypo was a powder....did you make a slurry before you poured it?
    The muriatic acid was 31.45%, correct?
    That problem has not been reported here before but I don't remember it being done back to back in those apparent concentrations.
    The pool is certainly safe to swim. The worst case is the acid damaged your pool surface and the stain is permanent. Best case is it may go away in a few days. I can't think of anything you can do now to fix it either way.
    Aug 2015
    Easton, PA
    4
    Good news. The stain disappeared. Was worried for a minute. Thanks for the comments everyone. I will definitely take Dave's advice and NOT add chemistry like that again!
    Inground pool
    Gunite
    aqua rite SWG
