Results 1 to 8 of 8
Thread: Concentration of bleach
    Aug 2015
    Lac La Biche, Alberta
    20
    Good morning! I am having a hard time finding the concentration of bleach in any store. Can anyone tell me how you determine this? Is it possible that the concentration is listed on the bottle in the US, but not in Canada?
    Thanks!
    15,500 gallons, vinyl, AG. Sand filter, 1 HP Hayward pump, installed June 2015, Taylor K-2006.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Concentration of bleach
    Experience tells me that if it isn't listed on the bottle (store brands mostly) it ain't what you're lookin' for. Usually 3% for cleaning chicken coops and such!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Canada doesn't require it to be listed. We have had other discover the same thing. Do some searching around the site and I'm sure you'll find good info. Maybe look at the thread called Bleach prices 2015.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    20
    Thanks for the responses!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    If all else fails, call the manufacturers and see if you can get it out of them. If that fails, you'll need to do the bucket method and test it for yourself to figure it out. Fill up a bucket with a known amount of chlorine-free water and add a known amount of your bleach and then test it with your kit. You'll want to do the FAS-DPD (Chlorine Drop Test) test for high accuracy.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    I used the tub one time out of curiosity. C/P:
    I found a gallon jug and timed how long it took to fill. 8 seconds. At first I was going for 50 gallons but my tub wasn't big enough. So I halved everything to 25 gallons.
    8 x 25 / 60 = 3.33 minutes or 3:20 to get 25 gallons in the tub.
    Pool math said add 0.3 oz of 12.5 bleach for FC of 10, 11, 12, and 13 so I figured 12 was close enough to the middle to avoid rounding error. Using the TFT vials I eyeballed 8.8 ml (.3oz) of bleach, did the test and got 22 drops (11 FC)
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Well, I've only been north of the border a couple of times, but everyone says you can get everything at Canadian Tire. From reading posts here, that includes liquid pool shock, AKA higher % pool chlorine.
    Check them out and see if they still have it.
    Support the site
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by tim5055 View Post
    +1
    They have 10.8%
    Aquarius Liquid Chlorine, 5 L | Canadian Tire
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
