Results 1 to 7 of 7
Thread: "LO" salt reading on saltron retro & low FC- how to fiix?
    Aug 2015
    Staten Island, NY
    14
    Have 5,500 gallon pool (12x20 above ground). No problems until now. Said LO salt yesterday and low FC and I put in half bag of salt. How long should I wait until both levels go up?
    I put bag in yesterday
    Aug 2015
    Staten Island, NY
    14
    Re: "LO" salt reading on saltron retro & low FC- how to fiix?
    I put bag on yesterday around 2 pm
    Aug 2015
    Staten Island, NY
    14
    And pool water is crystal clear. All other chems are good, but CYA is a little low
    Apr 2014
    FOUR cORNERS
    111
    test first, what ever you do don't add salt!!, look at your SWG and see if you see any white crystal build up, if you have hard water like I do you will have to remove SWG and clean, follow directions on cleaning, I use white vinegar, close valves, if sand filter put in closed position, and close return valve, remove SWG, fill with vinegar let set for a few hours, I usually let set overnight, reinstall all good for about a month. Papa
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Aug 2015
    Staten Island, NY
    14
    No white crystal buildup. Just checked salt level now and it says normal. I'll run it again overnight and check chems tomorrow to see if FC goes up. I'm also cleaning pool filter tonight too bc the water flow seems a little low (I think).
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    I also have the Saltron
    When I add salt It usually only takes an hour or so to come back to green.
    depending on how many hours you have oit set to it may take a day or 2 to get the Fc up
    Depending on what the level was to start
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Aug 2015
    Staten Island, NY
    14
    Chems good. Filter cleaned and flow good but still says LO. What should I do now?
