Results 1 to 18 of 18
Thread: Green trying to come back
    Jul 2008
    NJ USA
    146
    past 3 days the Green algea is trying to come back here are some #s
    FC 10
    CC 0
    TC 10
    PH 7.2
    TA 30
    Calcium Hardness 210
    I floowed the pool calulator and added goods to bring the TA up to 90 and PH to 7.8 the water is a bit cloudy due to algea but i still see the floor of the pool ant thoughts ? can the TA being low cause the algea to grow ? also last weeke end i added some water to the pool.
    19000 Gal. Fiberglass Inground 44x18 irregular shape pool
    Heat Siphon heater , Cooper Ind. Ranger Series Sand Filter, 3/4 HP Speck pump, Astral inline Chlorinator
    Aquacheck and TF100 tester
    NJ USA
    30,415
    Re: Green trying to come back
    TA has nothing to do with algae. Algae grows in a pool because there is not enough chlorine to kill it. read "The ABC's of Pool Water Chemistry" up in Pool School to get a better grasp of the chemistry.
    You also do not report CYA which is an essential part of your pool chemistry.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed,
    Algae grows when there isn't enough free Chlorine in the water and TA is irrelevant to that. Please post the Cya level, and let's work it from there.
    Essential Links:
    Jul 2008
    NJ USA
    146
    Ok been filtering round the.clock brushing and.robot is running to back.washed.a.few.times.In past 4 days water looks.good but algae keeps.coming back set of.new number s
    FC 10
    CC 0
    TC 10
    PH. 7.5
    CH 220
    CYA 100 + plus cause the full line is.just under the 100 grad line so .guess like 120?? Any advise is appropriate ed
    Also there is little viewing bubble.on my valve which one can see the water when.backwashing there was some.green algea in there I bleached it and ran the back.wash rinse every time I backwashed it is algea free now
    NJ USA
    Jun 2014
    15,074
    There's your problem! The dreaded "CYA too high" piece of the equation. Whenever your CYA is over 100, we know it could actually be much higher. The only remedy is to do a partial drain(s). Depending upon your location (please add later to your sig), you may have a high water table to be aware of. FB pools like our also have cautions about lowering the water level. But you need to remove/exchange water to lower the CYA or you will never be able to keep enough FC (chlorine) in there to compensate.
    Try doing a 25% drain if you can. You actually may need to do 2-3 of those to get your CYA down to a respectable 50-60 range. Only after you lower the CYA can you then start a "SLAM" to really attack the algae.
    Step 1, do a partial drain(s) to lower CYA somewhere between 40-60. The lower you go, the less bleach you will use during a SLAM
    Step 2, Read-up and prepare for the Pool School - SLAM - Shock Level And Maintain be ready to reference the Pool School - Chlorine / CYA Chart as well.
    After the drains and lowering of CYA, make sure you lower pH to 7.2 before starting the SLAM.
    Jul 2008
    NJ USA
    146
    Thank you I thought the CYA was high any idea what it drifts up BTW I am I
    In NJ
    NJ USA
    domct203's Avatar
    Jun 2015
    CT
    3,579
    Quote Originally Posted by rezasaba View Post
    In NJ
    The only way to raise the CYA level is to add CYA.
    I see an "Astral inline Chlorinator" in your signature, how have you been chlorinating your pool?
    You are aware that chlorine tablets add almost as much CYA as they do chlorine, right?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    15,074
    Yeah, that was a very possible scenario. Past use of tablets/pucks and also those bags of shock from the pool store. You've heard the saying, "I'm going to bomb my pool this weekend", well, while they added some chlorine, they are adding tons of stabilizer. Hence, the extremely high CYA most people didn't know about. The pool store sure won't tell you that.
    Jul 2008
    NJ USA
    146
    I have been using the chlorine pucks and some bleach as well but usage of the chlorine tablets are fairly low compare to previous years I am draining the pool as I post this my chlorine level has been around 10 all this season I realize it must be lower oncei get theCYAlevel down I will keep the chlorine level much lower another issue I have has been the trees I get a lot of air born pollen leaves also frogs mouse in the pool this pool is a magnet for various critters as well as bats diving in once the sun goes down son lts of visitors that's why I am a bit worried so that keep the chlorine high to combat the critters entering the pool and drowning
    NJ USA
    Jul 2008
    NJ USA
    146
    OK drained the pool fill the tank up with water again I got some new numbers
    FC. 3
    CC. 0
    TC. 3
    T/A 80
    PH. 7.2
    CH. 170
    CYA 60
    water is clear the temperature is around 72 I added one gallon of bleach this morning and that should bring it up to about 8 for the chlorine level any thoughts on this I appreciate your help
    NJ USA
    Jun 2014
    15,074
    Looking much better! Wow. Temp of 72. Mine was like 90 yesterday. Uhg.
    Jul 2008
    NJ USA
    146
    FC. 3
    CC. 0
    TC. 3
    T/A 80
    PH. 7.2
    CH. 170
    CYA 60
    NJ USA
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    8 would be great, lol.
    Jul 2008
    NJ USA
    146
    Huh?
    Yes cause I just replaced almost 5k gallons with fresh water
    NJ USA
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Huh?
    An FC of 8 is a good spot for a CYA of 60, is what I meant.
    Jul 2008
    NJ USA
    146
    once i get the algea under control how often should i add plain bleach if i stop using the chlorine tablets?
    NJ USA
    domct203's Avatar
    Jun 2015
    CT
    3,579
    I test & add daily. Takes about 10 minutes of my time
    Dom
    Dom - TFP Guide
    Jul 2008
    NJ USA
    146
    ok so far water is blue and clear drained some more water today and added some to bring the CYA down to my goal of 30
    NJ USA
