Results 1 to 7 of 7
Thread: How to clean glass tile at waterline
    Feb 2014
    Texas
    42
    Good evening members,
    Does anyone have any recommendation for a good glass tile cleaner? My glass tile at the waterline is dull and has lost some shine. I'd like to clean it. My glass tile is from NPT but before I go investing into the chemicals in the link below I'd love to hear from you guys.
    Oceancare Products
    JoyfulNoise's Avatar
    May 2015
    13,198
    Re: How to clean glass tile at waterline
    Are you trying to clean or seal the tile?
    Is it just haze or thick calcium scale on the tile?
    Can you post a picture?
    Matt
    Feb 2014
    Texas
    42
    JoyfulNoise,
    I'm trying to clean the tile first. I'm open to a seal but need to get it clean. It's a haze.
    May 2015
    13,198
    The cleaner product looks like some kind of dilute acid. If it's haze have you tried a 4:1 (H2O:muriatic acid) dilution in a spray bottle? What color is your grout?
    Matt
    Feb 2014
    Texas
    42
    Unfortunately my grout color is black.
    Jul 2013
    Frisco, TX
    19
    I use a magic eraser once a month. Cuts the haze. A couple times a year I use a cleaning pumice stone to remove any calcium build up, or whatnot.
    TF-100 XL w/ Speed Stir
    South facing, roughly 10,000 gallon inground L shapped PebbleSheen with spa (plastered 7/30/2014 and filled 7/31)
    Jandy Pro Series Filter Cartridge 580 SF, Jandy Pro Series ePump Variable Speed Pump, 2.0HP
    Feb 2014
    Texas
    42
    Figured Ií would update this thread since Iííve found a solution that works for me.
    -hire someone to powder blast tile line to remove calcium silicate. Nothing else will remove it not even muratic acid.
    -use scalefree plus from pool chemistry. You can buy it at Leslieís pools. This is absolutely needed where you have high hardness levels.
    -I use borates to keep PH at consistent levels. Without it, I fluctuate too much. I use poolproof for ease of use.
    Itís been almost a year since my glass tile was powder blasted and the tile line looks amazing. I think eventually Iíll need to powder blast again but my goal is to prevent quick calcium silicate buildup. Hope this helps someone out there.
