Thread: The Poolcleaner 4X Suction Pool Cleaner
    I have the Poolcleaner for about 4 years. It has worked great until recently. It is moving in the deep end and does not climb up the wall or climb to the shadow part of the pool any longer. One left wheel fell. Is 4 year about the end of its life?
    Jun 2015
    Wildomar, California
    423
    Re: The Poolcleaner 4X Suction Pool Cleaner
    I've sold several of those, yeah, 4-6 years, then the plastic parts start to break. But I love it as a cleaner!
    Jun 2011
    Carlsbad, NM
    171
    The inserts that the axles screw into are glued in. The glue breaks down, inserts get loose and causes the axles to wobble. With a hex key, remove the wheel, and epoxy the threaded insert back in. Might buy you a little more time.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
