Results 1 to 9 of 9
Thread: Water Circulation Issue
    Aug 2015
    az
    6
    Hi gurus
    I am having issue with water circulation. I have sand filtration system (triton II) and Hayward pump system. The pressure was getting high so I performed routine backwash like usual. This time, when I put it back to filtering, pressure is still high and I also lost flow from both inlet (skimmer and vacuum) and outlet. I can't feel any suction on inlet and I do not see anything coming out of the outlet. I can still perform backwash just fine which I think it tells me that the pump is working. I checked all surfaced plumbing and did not notice any leak.
    What do you guys think?
    Thanks in advance
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Water Circulation Issue
    I,would be looking at the multiport valve. When you put it in backwash and water is flowing you will still have suction from the drain/skimmer, so that is out of the picture. That points to the multipoint valve.
    Google your make/model valve and you should be able to find a manual and usually an exploded parts diagram to figure out what is going wrong.
    Support the site
    Aug 2015
    az
    6
    Quote Originally Posted by tim5055 View Post
    Thanks for your quick reply!!
    I have this simple turn and push down handle mechanism to put it in a backwash mode. When I done, I simply pull the handle back up and twist to lock it for regular filtration mode.
    May 2014
    Franklin, NC
    9,184
    Well, if it works in backwash mode and doesn't in filter mode then something is wrong inside that plunger valve. If you pull it up to go back into filter mode I'm going to guess the rod has somehow disconnected from the slide and the slide is staying I'm the lower backwash position. Do you have valves to turn off the water to that valve to try to disassemble it to see what is going on?
    Support the site
    Aug 2015
    az
    6
    I have not had chance to do that yet. Thanks for your recommendation. I will try that see how it turns out!
    Aug 2015
    az
    6
    Thanks Tim. You were dead on. Bottom part of pentair backwash valve broke off. I got the replacement part however I can't locate the broken end. I think it is lodge somewhere restricting the flow. I don't want to start cutting the pipe but looks like that is what I have to do. Any suggestion is welcomed.
    Thanks
    May 2014
    Franklin, NC
    9,184
    I wish I had one. I've never done surgery on one of those, so I'm not sure what to recommend other than cutting it out and replacing it.
    If you are buying parts anyway I think a multiport valve is more versatile than the simple push/pull valve you had.
    Support the site
    Aug 2015
    az
    6
    Long story short, I had to cut the pipes. It was lodged in pretty tightly restricting 100% water flow back to pool. I used union this time to put it back together in case I need to take it apart later and it finally working!!! I searched online looks like I was not alone. It is pretty common issue. I had to get this up and running as quickly as I can but next time if it happens, I will definitely replace it with multiport value like you suggested.
    Thanks for help!
    May 2014
    Franklin, NC
    9,184
    Glad it worked out.
    Support the site
