Results 1 to 9 of 9
Thread: Looking for valve identification
    Aug 2015
    Folsom Prison, CA
    124
    Hello, hope you don't mind a question from a newbie!
    Threads merged. Please keep all related posts in one thread. It's hard to know what's been said if the same issue is in several threads. Bama
    I just purchased a house that has a pool and I need a little help understanding my setup. The thing I am most concerned with is the valve in the middle of the gear. I am not sure what it is for and which way it should be turned. It is in a kind of cocked position right now that doesn't look like it is fully opening or closing any which way. Any help please?
    http://i.imgur.com/wfzzfIR.jpg
    Thanks!
    Aug 2015
    Folsom Prison, CA
    124
    Hi I just moved into a house with a pool and I am not sure what the valve in the middle of all the gear is supposed to be set to. Right now it is in a position that would not be fully opened or closed any which way. Is that normal? Any insight on this valve would be great. Thanks.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Looking for valve identification
    Hello censored, it's hard to tell from that angle, but it looks like that valve controls the flow from the filter to the pool (line on the right going to pool ?) and the left one is waste when backwashing (to sewer line ?)
    Or I could have it backwards
    someone will be along to help/ If you could get a pic from above so we colud see where the lines in back are going ,that might help.
    And .. Welcome to TFP
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Hello, hope you don't mind a question from a newbie!
    Can you post another photo from the end by the pump it is hard to tell which pipes go where with just the one photo
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,541
    Censored,
    Does your pool have a waterfall, water feature, or slide? As lefty51 has said, another view of the set up would help, along with a picture or description of your pool would also be helpful.
    Jun 2015
    Raleigh
    357
    Looks like a Hayward multiport Valve....Different Positions do different things. It redirects flow to the filter or to waste (that pipe going along ground behind filter I suspect)
    Multiport Valves | Filters | In Ground Pool Filters - Hayward Pool Products
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Gilbert, AZ
    130
    Mine has a plunger valve for Backwash vs. regular filter. I have only one valve and that controls the amount coming in through the cleaning port vs. the skimmer. It's possible your setup is similar, but like they said it's tough to figure out.
    12000-ish In Ground, plaster, sand filter. New variable speed pump (Hayward I believe)
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Yes, move to your left and turn 90-120 degrees and take another pic. There are some pipes back there that is hard to tell where they go from this single picture.
    However, I think robertmee is correct.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Looks like we have two posts of the same thing...Mods?!
    ----Chris----
