Results 1 to 7 of 7
Thread: :( clouds in my coffee (pool) this am..what did i do wrong with my SLAM
    Jul 2015
    franklin/tn
    96
    Ok so I'll try to be brief; I SLAMed for roughly 7 days. At the start CYA was 60 (so I think I needed to maintain 24) and then droppped to 50 by the end (evaporation, vacuuming to waste & adding new water plus rain) so I kept it at 20 after it changed.
    I have maintained OCLT < .5 for several nights now even as the FC has slowly dropped (9.5 last night and 9.5 again this AM..CC at .25 or so..1 drop turned it clear)
    I brushed & kept debris to a minimum (usually a handful of leaves in the pool I net out each morning before work)
    Filter pressure is steady
    This morning when running my FC test I *thought* I could see a film in places but told myself maybe it was debris falling apart overnight. Nope, it was algae and I had to brush the whole thing before I left for work.
    So, here are the things I think I've done wrong so far (please let me know if there are others)
    1. I haven't vacuumed to waste in several days. I just 'net' the large debris out of the pool and when done each morning I don't visibly see ANYTHING on the bottom.
    2. I brushed out underneath my ladder (the only thing touching the water) but I have *NOT* pulled out the pool light because I don't know how. I guess I am about to learn..maybe this was the culprit?
    3. I have not brushed in 2-3 days (yeah I know..shame shame) because I've been really busy and it didn't appear to need it.
    4. I always test in the same place every time; on the left side 1/2 down the pool. Maybe I should find a new 'less chlorin-ey' area in the water to use as my FC location?
    I assume I should probably correct all 4 of those but are there other things I've missed in this process? I am getting low on test powder so I don't want to mess up the SLAM.
    I quickly brought the FC back up to 20 this morning right after noticing the problem but what else should I be doing to ensure the algae is 'really gone' next time?
    I thought everything looked all clear on the testing but maybe I let the FC start to drift down too soon?
    33x15' INGROUND pool roughly 14,800 gallons. liner, hayward multiport, sand filter (S-210S), pentair century 3/4hp pump (1081) & 320 automatic chlorinator. skimmer at one end of pool, 2 returns at the other.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: :( clouds in my coffee (pool) this am..what did i do wrong with my SLAM
    Are you seeing green, or white dead algae? Floating, or stuck on pool surfaces?
    Jul 2015
    franklin/tn
    96
    just that greenish color that as i brush generates a little cloud. it was MOSTLY on the bottom, not as much on the sides
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hello, ok I'm going to ask. you had <.5 FC loss, <.5 CC overnight, BUT was your pool also crystal clear. I'm betting you had hidden algae in the light and you weren't done SLAMing yet.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Jul 2015
    franklin/tn
    96
    yeah i was afraid of that. i will take some time today to mess around with the light and see if i can figure out how to remove it. surely its just a couple of screws right?
    thats the only thing i can think of that is still in the water..its just a basic vinyl liner pool.
    Aug 2014
    Northern IL
    4,615
    It's usually just one screw at 12:00 position. It should be barely tightened. When I do mine, I have my vacuum set up with someone at the filter to switch it to waste when I pull the lights.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    we have seen a light or two that didn't have a screw and were a 1/4 turn CCW if I remember correctly.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
