Thread: CYA test with TF kit
    Sep 2011
    So Cal
    155
    Following the instruction, the mixed solution is always more than enough to do the black dot test. Can I do it with half of the water and solution? This should result the same ratio to test with.
    My other question is, seeing the guy at the pool store using the same test but since it's indoor (the black dot probably don't appear as dark), his result should be higher than when I do the test out in the backyard, correct?
    I asked because my recent test showed 70 and the pool store's was 40, reversed of what I mentioned above.
    Thx
    35k Gallon, 2 In Piping, Aquarite, KK, Spa, Water Fall.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: CYA test with TF kit
    With pool $tore you can never tell for sure what they are doing. It's best to just stay away if you can.
    You can use less as you suggested. Just make sure it isn't too little to get the reading you need. Be very sure to use equal amounts of pool and reagent.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2011
    So Cal
    155
    Thx. So far it works but I guess unless my CYA is way too low then I need to add and retest anyway.
    Donldson's Avatar
    NW Ohio
    2,904
    Just ignore pool store results, they will only confuse you. In fact, they did exactly that, so I rest my case
    If you measured your CYA as 70 then that is what it is, don't retest because some guy at the pool store got an entirely different number. His job description is to make sales, not deliver accurate testing.
    As long as there is a 1:1 ratio of water to melamine (the CYA reagent) then the results will be accurate.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Quote Originally Posted by amati5 View Post
    70 CYA is fine. Why raise it if it's working?
    And the scale is upside down, so lower level means higher number.
    Sep 2011
    So Cal
    155
    What I meant was the way I tested with half the liquid and it's been ok unless the CYA is way low which require more liquid to see the actual reading which I might not have enough. And if it's that low, I have to add CYA anyway.
