Thread: When are you testing for chlorine?
    Mar 2015
    Las Vegas NV
    460
    I test chlorine and pH daily, usually first thing in the morning. My pump/swg have been of for at least 12+ hours when I'm testing, should I be testing while pump/swg are running or shortly after vs. when I'm currently testing? I turn my pump on immediately after my morning test.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: When are you testing for chlorine?
    You should test after the water has had a chance to mix a little bit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I always test after my pump has been running for at least 30 minutes.
    Isolated Spa - 345 Gallons
    Mar 2015
    Las Vegas NV
    460
    So you're testing shortly after the pump has started vs. the end of the daily run?
    Feb 2014
    Central Minnesota
    5,080
    My pump runs two different sessions of about 3 hours each. If I need to test, I test any time in those two sessions after it's been running for at least 30 minutes. If I need to dose and I've happened to test at/near the end of a session, I'll extend the run time by 30 minutes.
    Apr 2010
    East Texas
    9,569
    The benefit od testing end of day is in having your FC levels high enough to be sanitizing over night vs. being at minimum levels.
