Thread: Is the new Pool Blaster reliable?
    May 2013
    Toronto, Canada
    73
    Water Tech came out with a revamped electric vacuum. Has anyone who had problems with the old line had positive or negative results with it?
    I had 3 Pool Blasters, the last being a Pool Blaster CG ( Commercial grade). None lasted longer than 3 months. On the other hand many people have used them for years with no problems. Water Tech was very good in supporting me through all the hassle so I am tempted to give this new one another chance. Unfortunately a 3 month warranty on electrical parts is not great and that seems to be what fails.
    Anyway, any information regarding the new design would be appreciated especially regarding quality control and design changes.
    Philip
    12.5x21.5x52" on-ground 29" below ground (6000 gallons water), .85 HP Hayward SP26115VSP , Hayward XStream 100 sq.ft. cartridge filter, Hayward AquaRite salt system, 160 sqft of Aquatherm solar panels on 12' high flat roof 25' away from pump, Goldline auto controller for solar, Heat Pump, May->October @77+ in Toronto, Pool Python.
    Jun 2015
    Freehold, NJ
    20
    Re: Is the new Pool Blaster reliable?
    I can't comment on the new Water Tech line, but I can tell you about my experience with the Ivac M3.
    I'm on my third full season without any issues. While charging I make sure to unplug the charger as soon as the red light turns green. I find that it requires about a 1.5 hour charge after each use, so it's easier to time and unplug. Also during the off season, I give it a full charge about once a month. I check the plug after each use and lubricate as needed to protect the battery. Hope this helps.
    20x40 rectangle IG vinyl, 22000 gallons, non-SWG, sand filter, 1.5 hp Hayward super pump, self-priming,
    TF-100 test kit, speedstir, Dolphin Deluxe 4 Robotic pool cleaner, Poolblaster Ivac M3 vacuum.
