Results 1 to 11 of 11
Thread: Any suggestions for increasing CH without breaking the bank (early August - no deicer
    Aug 2014
    VA Beach VA
    4
    I'm still new to pool maintenance. Wow, Thank Goodness for this site and the forum - and Thank You to all you pros for sharing your wealth of knowledge!!!!!! I have a CH level of 33. It is a plaster pool, but was recently painted and coated with something that is very slippery. I need to increase the hardness (obviously with a level of 33) - but don't have $100 to spend at the pool store. It's early August and none of the hardware stores have any de-icer in stock. Any other suggestions how I can increase this without breaking the bank?
    Thanks!!
    27,000 gallons plaster in ground with Hayward Sand Filter. The pool is older but was repainted this year.
    22,550
    Re: Any suggestions for increasing CH without breaking the bank (early August - no de
    Try the local farm store. They usually have calcium in stock for farmers use. It's the same stuff used in pools or as deicer.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    its not sold locally at home depot/lowes right now...however, you can still buy it online from them and ship to the store for free!
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2014
    Gulfport, MS
    67
    Quote Originally Posted by bzbmom View Post
    Out of curiosity, what test kit are you using? or how did you come up with a CH of 33?
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
    Sep 2013
    Charleston, SC
    537
    I live in coastal SC and we never have de-icing materials in our area! I found this link and bought from them Calcium Chloride Anhydrous - ChemistryStore.com They are great to deal with.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Aug 2014
    VA Beach VA
    4
    Quote Originally Posted by Bama Rambler View Post
    Thank you so much!! My local farm store had it in stock. Less than $20 for a 50 lb bag. Much better than the $80 I'd have to spend at the pool store
    Quote Originally Posted by ScottCh View Post
    I got the number from a local pool store. I went in to buy shock and have the water tested.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Ah, pool store measurements...that explains it.
    The test for CH is a drop test (titration) and each drop represents 10 ppm of Calcium so normally you don't get in the ones place on the reading. Mine takes 23 drops so x10 and my CH is 230.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Aug 2013
    Arab, Alabama
    422
    Chris - I think the CH titration is in 25 ppm increments. If it takes 23 drops your CH would equal 575. Please correct me if I'm mistaken.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Quote Originally Posted by jaduck View Post
    A 10ml sample = 25
    A 25ml sample= 10
    You use a lot less of the reagents if you CH is over 100 by doing the 10ml method
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I do the 25 ml sample...good to know with the 10 ml sample size...I'll start doing that.
    ----Chris----
    Aug 2013
    Arab, Alabama
    422
    Thanks for the info! Forgot about using a larger sample size!
