Results 1 to 8 of 8
Thread: Does the salt cell have to be the "highest point of plumbing?"
    Jan 2015
    Northeast Georgia
    19
    I am installing a Saline Generating Systems "Breeze 540" SWCG. I am about to install the salt cell on the return line. The installation manual says the cell "must be located above the highest point of plumbing." On another page the manual says, "The cell housing should be located 6 inches above the height of plumbing: in the event there is no heater, the cell should be located above the height of the filter inlet and outlets." (I do not have a heater, except for solar.) Is all this altitude actually required? My return line is 3 inches above the ground, whereas my filter lines are 39 inches above the ground, so if I'm understanding this correctly I must install 42 inch risers on my horizontal return line to raise the salt cell 6 inches above the filter lines? Really?
    Thanks for any feedback.
    Philip
    20.3K gal, IG vinyl, Hayward S244T sand, 1HP Hayward SP2607X10 pump, Saline Generating Systems "Breeze 540" SWCG, circa 2000, TF100/SpeedStir, 5 AquaSol AQ48 solar panels, Intermatic PF1103T 1.5/3HP Timer, Kreepy Krauly Classic
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Does the salt cell have to be the "highest point of plumbing?"
    I'd sure give them call and ask them why. The pressure and rate of flow won't change.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I have not heard of this requirement before and I know many SWG cells are installed well below the highest point in the plumbing. I've seen several installations (in fact every one I've seen) where the SWG is installed just 6 inches to a foot off the pad while there are obviously return/suction lines running to the filter multiport valve that are well above that. At least two installations I've seen the SWG and the equipment pad are below the altitude/grade of the pool surface itself.
    Isolated Spa - 345 Gallons
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    I agree with woodyp, I'd call and ask why. Is it something about that particular system ?
    Mine could be mounted horizontally or vertically. The only requirement was where in the system line it was located (i.e in the return line after pump, filter, heater etc)
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    They're just using redundant safety systems. If there is some sort of malfunction, they don't want Hydrogen gas building up in the heater and pulling a Hindenburg on you. The manual I'm looking at says
    The cell housing should be located 6 inches above the height of the heater: in the event there is no heater, the cell should be located above the height of the filter inlet and outlets.
    That shouldn't be so hard. It doesn't say above the filter, just above the filter plumbing.
    Some places, like Australia, require a "gas trap" design. The cell contains a safety sensor that detects excess gas buildup.
    The design traps gas in the cell and prevents the cell from generating more gas than what would cover the plates in the cell. Once the cell fills with gas (hydrogen gas and chlorine gas), no more can be made because the plates are not covered in salt water.
    I would suspect that the system is manufactured by a company that makes systems for the Australian market.
    Support the site
    Apr 2010
    East Texas
    9,643
    Great answers Richard and James!
    Jan 2015
    Northeast Georgia
    19
    Thanks for the replies, everyone.
    Richard and James, your replies made a lot of sense to me, and I installed the salt cell per the directions. I'm glad I did--the housing is transparent and it is so easy to inspect the plates for build up with the cell so high off the ground! IMG_1882.jpg
